Felt in FEM Workbench
Sudhanshu
Re: Felt in FEM Workbench
Postby Sudhanshu » Sun Apr 07, 2019 9:20 pm
bernd wrote:
Sun Apr 07, 2019 8:27 pm
As stated, to get started just use gmsh.
Ok, I will start with Gmesh.
Thanks!
vocx
Postby vocx » Sun Apr 07, 2019 9:41 pm
Just to make clear. Netgen was never included in FreeCAD source. FreeCAD needs to be compiled and linked against Netgen to make Netgen mesher inside FreeCAD working. May be, may be not, the provided FreeCAD binaries for various operating systems include netgen mesher or not!
You are right. I didn't word that exactly correctly. What I meant to say is that in the free software world, especially with a license like GPL, linking against a particular library is somehow considered "including" that library in your code. So, currently Netgen isn't linked against FreeCAD, but of course, it can be used externally, just like Gmsh is.
hardeeprai
Postby hardeeprai » Mon Apr 15, 2019 4:27 pm
@ Sudhanshu
Anything worth to report?
H.S.Rai
Sudhanshu
Postby Sudhanshu » Tue Apr 16, 2019 11:31 am
@ Sudhanshu
I have created the basic versions of solver.py, writer.py and tasks.py.
You can view the files here.
Now I need to register felt solver in various files.
I have some doubts in the tasks.py.
What does the Container class do? Does it store the various parameters like constraints and material properties?
# get member, empty lists are not supported by oofem
self.materials_linear = []
self.materials_nonlinear = []
What is the meaning of "member" and "empty lists" here?
bernd
Postby bernd » Tue Apr 16, 2019 7:24 pm
yep the analysis member are collected and tbey will be parameter for the writer class. Empty lists is empty thus an ampty list will be given to the writer and thus the writer can not write this constraint and thus this constraint is not supported by the writer. Since your input file is a string in writer ATM you can pass a bunch of empty lists to the writer. If your solver runs you can step by step give live to the empty lists and implement the writer for this. Just see the oofem commits.
cheers bernd
looks good so far. Does the solver run? I assume not because you did not adapt the settings module and some other things. see first two commits in oofem
Sudhanshu
Postby Sudhanshu » Thu Apr 18, 2019 6:56 am
So I was editing the settings.py and came around the following code which I didn't fully understood:
"oofem": _SolverDlg(
        default="oofem",
        param_path=_PARAM_PATH + "oofem",
        use_default="UseStandardOofemLocation",
        custom_path="OofemBinaryPath"),
Here you are adding values to the _SOLVER_PARAM variable but I don't understand exactly how and what do these values mean?
Similarly in testobject.py, what are following lines doing:
        self.assertEqual('Fem::FemSolverObjectOofem', type_of_obj(ObjectsFem.makeSolverOofem(doc)))
        self.assertTrue(is_of_type(ObjectsFem.makeSolverOofem(doc), 'Fem::FemSolverObjectOofem'))
        self.assertTrue(is_derived_from(ObjectsFem.makeSolverOofem(doc), 'App::DocumentObject'))
        self.assertTrue(is_derived_from(ObjectsFem.makeSolverOofem(doc), 'Fem::FemSolverObject'))
        self.assertTrue(is_derived_from(ObjectsFem.makeSolverOofem(doc), 'Fem::FemSolverObjectPython'))
        self.assertTrue(is_derived_from(ObjectsFem.makeSolverOofem(doc), 'Fem::FemSolverObjectOofem'))
        self.assertTrue(ObjectsFem.makeSolverOofem(doc).isDerivedFrom('Fem::FemSolverObjectPython'))
@Bernd, can you please explain these lines to me.
Sudhanshu
Postby Sudhanshu » Thu Apr 18, 2019 7:16 am
I have followed the first two commits.
You can check them here.
So, the solver should run now right?
But how can I test it?
I don't think that it will appear in the FreeCAD that I have since its the one I installed using apt.
Should I compile my repo and install that FreeCAD, or is there any other way?
hardeeprai
Postby hardeeprai » Sat Apr 20, 2019 6:22 am
In your sample file written inline at https://github.com/Sudhanshu-Dubey14/Fr ... /writer.py , the lines from 127 to 135 are not needed, as these are for GUI of FElt, named "Velvet", which will not be used in your case.
H.S.Rai
hardeeprai
Postby hardeeprai » Sat Apr 20, 2019 6:42 am
Refer file name "1DBeam.out.m0.1.vtu" mentioned at line number 124 of https://github.com/Sudhanshu-Dubey14/Fr ... t/tasks.py
With your current code, you can't create this file.
H.S.Rai
hardeeprai
Postby hardeeprai » Sat Apr 20, 2019 6:44 am
... I installed using apt.
When you do development in Python, you need not to compile FreeCAD.
H.S.Rai
