missing stress values Sxy, Syz, Szy
HarryvL
Re: missing stress values Sxy, Syz, Szy
Postby HarryvL » Wed Jan 30, 2019 4:14 pm
Yes it is already used extensively.
bernd
Postby bernd » Wed Jan 30, 2019 6:52 pm
and it is great to have it, but does not help if we gone disscuss property data structure of FreeCAD objects ...
bernd
Postby bernd » Fri Feb 08, 2019 11:38 am
I have something working ...
how about these names for VTK ?
code is here. First the FreeCAD result property name than the VTK name ... https://github.com/berndhahnebach/FreeC ... #L661-L703
If someone would give it a try which is highly appreciated ... https://github.com/berndhahnebach/FreeC ... ultreading
HarryvL
Postby HarryvL » Fri Feb 08, 2019 2:09 pm
Great!! Some really minor comments:
I would start “strain” with capital letter (ie Strain)
I would put them in the following order:
xx, yy, zz, xy, xz, yz (Just for convention sake. Same applies to stress)
I would drop “Cauchy” and capitalize Stress. There are many different stress measures, but the default is Cauchy. So if nothing is mentioned it is clear Cauchy is meant.
I would drop “magnitude” after Principal Stress.
PS: I am traveling so won’t be able to test soon
bernd
Postby bernd » Fri Feb 08, 2019 2:58 pm
great ... I will do the changes in the regard of you comments. One hint ... stress and strain conventions I used from CalculiX frd file. See https://github.com/FreeCAD/FreeCAD/blob ... #L844-L850 But if yours ist standard FEM mathematics I would use yours.
Have you seen https://github.com/berndhahnebach/FreeC ... #L661-L703 the names in FreeCAD result property for stress and strain are NodeStressXX and NodeStrainXX ... How about them?
BTW they work in FEM result object user defined view as well as in vtk and in vtk file export. Means full access to them.
Testing ist not that important (I mean only in sense of the names, otherwise testing is highly apreteated any time :) ). I will rebase your concrete branch on that. For this some dev and testing will be required than. But thats another topic and story ...
HarryvL
Postby HarryvL » Fri Feb 08, 2019 3:20 pm
(1) One hint ... stress and strain conventions I used from CalculiX frd file.
(2) NodeStressXX and NodeStrainXX ... How about them?
(3) I will rebase your concrete branch on that. For this some dev and testing will be required than. But thats another topic and story ...
(1) I can only express my preference :)
(2) That is good alternative. Just so people know it’s nodal values and not at integration points.
(3) Just let me know if, how and when I can help.
bernd
Postby bernd » Sun Feb 10, 2019 1:00 pm
changed names and order
had to change calculation of principal and von mises stress too ...
https://github.com/berndhahnebach/FreeC ... #L327-L355
HarryvL
Postby HarryvL » Sun Feb 10, 2019 5:33 pm
Ah, great, I tested it this morning, but with the old names. I'll try once more
bernd
Postby bernd » Mon Feb 11, 2019 6:10 am
Just fixed the result task panel with the new names. From my point of view https://github.com/berndhahnebach/FreeC ... ultreading is ready for a PR. Would be great if you could give it another try, as you stated
HarryvL
Postby HarryvL » Mon Feb 11, 2019 2:29 pm
Looks good. I tried both result pipeline and Paraview and all descriptions are the same and make sense to me.
