fcFEM - FEA from start to finish
HarryvL
Re: fcFEM - FEA from start to finish
Postby HarryvL » Wed Mar 27, 2019 8:50 pm
Jut an update of where I am with this ...
I am cleaning up the code ahead of posting it as FOSS. Also putting a lot of TODO comments for ease of reference.
I updated the Matplotlib facility so that on the basis of how far you got on the curve you can decide to stop the calculation or continue by adding more load steps. I find this really intuitive and handy.
It’s not going as fast as I had hoped because I need adapt the interface elements to deal with load stepping, even for elastic response.
HarryvL
Postby HarryvL » Sat Mar 30, 2019 5:58 am
This is now ready for use:
https://github.com/HarryvL/fcFEM
Have fun !
bernd
Postby bernd » Sat Mar 30, 2019 6:15 am
Good Morning Harry,
wow, very cool stuff. Surely I will play with this, but it seams to me it is not done in 5 minutes ... :D
cheers bernd
HarryvL
Postby HarryvL » Sat Mar 30, 2019 6:20 am
Hi Bernd, it also took a while to put together :shock: . Load stepping and iteration are fully automated ... so that should help in getting up to speed with it and producing some results ;) However, now the framework is there it will be relatively easy to extend.
HarryvL
Postby HarryvL » Sat Mar 30, 2019 6:58 am
Please note that (for now) some material parameters need to be entered in the main macro fcFEM.FCMacro. The control parameters are best left unchanged unless you are brave and want to experiment. Perhaps the only exception is out_disp, because it allows you to chose between total or incremental displacements.
# material input values - TODO: merge with FEM WB input dialogues
gravity = -0.0e-5   # specific gravity acting in z-direction [N/mm3]
sig_yield = 100.0   # yield stress [MPa] for volume elements (von Mises material)
shr_yield = 100.0   # yield stress [MPa] for interface elements (Coulomb material)
kn = 1.0            # interface elastic normal stiffness factor (0.0 < kn <1.0)
ks = 0.0            # interface elastic shear stiffness factor (0.0 < ks <1.0)
# control input values - TODO: merge with FEM WB input dialogues
out_disp = -1000    # +n: output total discplacment at step n ; -n: output incremental discplacement at step n (if n>last step then n=last step)
nstep=10            # number of load steps per run (default = 10)
iterat_max=20       # max number of iterations per step - this triggers a scale-down and restart
error_max=1.0e-03   # convergence tolerance (default = 1.0e-03)
relax = 1.2         # numerical over-relaxation (1.0 < relax < 1.5; default = 1.2)
scale_re = 2.0      # scale factor for re-start (default = 2.0)
scale_up = 1.2      # scale up for fast convergence (default = 1.2)
scale_dn = 1.2      # scale down for slow convergence (default = 1.2)
I will post the relevant parameter selections that go with the case studies in my repo so you can give them a try.
bernd
Postby bernd » Sat Mar 30, 2019 7:24 am
I saw already. I could not resist to spend an hour to browse your repo :mrgreen:
HarryvL
Postby HarryvL » Sat Mar 30, 2019 9:37 am
Excavations in clay:
gravity = -2.0e-5   # specific gravity acting in z-direction [N/mm3]
sig_yield = 0.01   # yield stress [MPa] for volume elements (von Mises material)
shr_yield = 100  # yield stress [MPa] for interface elements (Coulomb material) - irrelevant, not used yet
kn = 1.0            # interface elastic normal stiffness factor (0.0 < kn <1.0) - not used for the clay examples
ks = 0.0            # interface elastic shear stiffness factor (0.0 < ks <1.0) - not used for the clay examples
Beam:
sig_yield = 100   # yield stress [MPa] for volume elements (von Mises material)
ks = 1.0            # interface elastic shear stiffness factor (0.0 < ks <1.0) - no slip
Circular punch:
sig_yield = 100000   # yield stress [MPa] for volume elements (von Mises material) - suppress plasticity
ks = 0.0            # interface elastic shear stiffness factor (0.0 < ks < 0.0)
HarryvL
Postby HarryvL » Sat Mar 30, 2019 4:56 pm
I moved my fcFEM.FCMacro and femTools.py out of the .FreeCAD/Macro folder to a local clone of my fcFEM repository. However, if I now run this fcFEM.FCMacro from the FreeCAD macro panel it returns an error that it cannot load module femTools. I put an __init__.py in the development directory and also did "export PYTHONPATH="${PYTHONPATH}:/my development path", which correctly show up in sys.path. However, despite all of this I still get: "<type 'exceptions.ImportError'>: No module named femTools". Can anybody help me resolve this? Thanks, Harry
HarryvL
Postby HarryvL » Sat Mar 30, 2019 5:12 pm
Something else ... I just pulled and built the latest FC source from femconcrete and it broke my fcFEM macro :shock: It looks like an additional parameter was added to the FemInputWriter constructor? I simply put another None at the initiation call of the relevant object and now it works again, but it makes me worry that any call to FC API is vulnerable? Also, it would mean that the macro would either work with 0.17/0.18 or 0.19, but not both. Any suggestions on how to manage this? Thanks, Harry
HarryvL
Postby HarryvL » Sat Mar 30, 2019 6:10 pm
I installed the Intel Performance Libraries and Distribution for Python on my Ubuntu 16.04 system following the instructions here: https://software.intel.com/en-us/articl ... n-apt-repo.
I tested the plate-with-hole example with 10 elasto-plastic steps. Intel MKL gave me a speed increase of approximately a factor 3. Not bad, but I have no idea if this is a typical improvement I should expect or if I should be able to squeeze more out of this library? Doe anybody have experience with this?
Next: Reverse Cuthill McKee band width reduction and use of a banded Cholesky solver. Let's see how fast this can get :D
