Compiling CalculiX ccx on fedora, ubuntu and debian
PrzemoF
Post by PrzemoF »
The script to build CalculiX ccx from scratch of fedora/ubuntu/debian [1].
1a. for FEDORA install git tar make bzip2 gzip make aprack arpack-devel lapack lapack-devel blas blas-devel
dnf install git tar make bzip2 gzip make arpack arpack-devel lapack lapack-devel blas blas-devel
1b. for UBUNTU/DEBIAN install git tar make bzip2 gzip liblapack-dev libarpack2 libarpack2-dev libblas3 libblas-dev gfortran
apt-get update && apt-get install git tar make bzip2 gzip liblapack-dev libarpack2 libarpack2-dev libblas3 libblas-dev gfortran
2. clone the repo
git clone https://gitlab.com/PrzemoF/calculix-build-script
3. cd into the repo
cd calculix-build-script
4a. ..and run script. It should produce ccx executable
FEDORA:
./fedora.sh
UBUNTU/DEBIAN
./ubuntu.sh
5. Start FreeCAD, open FEM workbench (required to get FEM wb properties in Settings)
6. Go to Edit->Preferences->FEM-CalculiX and set path to the newly compiled ccx file
[1] https://gitlab.com/PrzemoF/calculix-build-script
bernd
Re: CalculiX in fedora 27, 28 & 29
Post by bernd »
Post by Kunda1 »
PrzemoF wrote: Wed Feb 06, 2019 1:15 pm build CalculiX ccx from scratch of fedora [1].
[1] https://gitlab.com/PrzemoF/build-script ... -on-fedora
Maybe we can get Calculix in to Rawhide ?
PrzemoF
Post by PrzemoF »
You mean fedora rawhide? I think the script should work as well - I'll try to test it if I can run rawhide in gnome Boxes. Ubuntu flavours will be next on the TODO list as well.
Post by Kunda1 »
PrzemoF wrote: Wed Feb 06, 2019 6:32 pm You mean fedora rawhide? I think the script should work as well - I'll try to test it if I can run rawhide in gnome Boxes. Ubuntu flavours will be next on the TODO list as well.
Yes, Fedora Rawhide.
BTW, https://github.com/luzpaz/FreeCAD-depen ... /issues/30
PrzemoF
Post by PrzemoF »
The script works fine on rawhide as well. I need to put together a list of required packages (git, tar, gzip, bzip2, make + libraries) to make it foolproof.
PrzemoF
Post by PrzemoF »
Repo address changed to: https://gitlab.com/PrzemoF/calculix-build-script
I'm giving up with ubuntu for now - it's too weird for me (read: I don't know it). Getting installed package version is strange, names of libraries don't match dev packages and there is no arpack (or it's under some other name). I'll probably come back to it if there is any interest to compile ccx on ubuntu.
HarryvL
Post by HarryvL »
PrzemoF wrote: Thu Feb 07, 2019 10:10 am I'll probably come back to it if there is any interest to compile ccx on ubuntu.
+1
... and wrt making this “foolproof”, please count me in as a fool. I have no idea where to start. :shock:
PrzemoF
Post by PrzemoF »
:D
git clone https://gitlab.com/PrzemoF/calculix-build-script.git
Run the ubuntu.sh, read what's missing, install with apt-get, run again, repeat. Alternatively install all those before running the script:
I got great help on ubuntu channel, so the script should be almost ready.
PrzemoF
Post by PrzemoF »
sudo add-apt-repository universe
sudo apt-get install git tar make bzip2 gzip liblapack-dev libarpack2 libarpack2-dev libblas3 libblas-dev gfortran
./ubuntu.sh
Enabling Universe repo might not work on older versions of ubuntu, more here: https://askubuntu.com/questions/148638/ ... ory#227788
Edit: one-liner to build ccx for ubuntu 18.10:
sudo add-apt-repository universe && sudo apt-get install git ; git clone https://gitlab.com/PrzemoF/calculix-build-script.git && cd calculix-build-script/ && sudo apt-get install tar make bzip2 gzip liblapack-dev libarpack2 libarpack2-dev libblas3 libblas-dev gfortran && ./ubuntu.sh
