Should results be scaled for eigenmodes on result reading?
bernd
Postby bernd » Thu Feb 07, 2019 5:50 am
For the eigenmodes all results are scaled: https://github.com/FreeCAD/FreeCAD/blob ... #L232-L240 this was introduced from the beginning of frequency analysis. https://github.com/FreeCAD/FreeCAD/comm ... fa4929R212
IMHO these results should not be scaled on import!
How about other opinions? What does other software do?
bernd
bernd
Re: result scaling for eigenmodes
Postby bernd » Thu Feb 07, 2019 5:51 am
HarryvL wrote: ping
PrzemoF wrote: ping
HarryvL
Re: Should results be scaled for eigenmodes on result reading?
Postby HarryvL » Thu Feb 07, 2019 6:49 am
You’re right. Only the deformation shapes (eigenmodes) matter.
bernd
Postby bernd » Thu Feb 07, 2019 7:18 am
even they. IMHO we should calculate appropriate scalling on result viewing. The result obj should hold the the original solver results.
HarryvL
Postby HarryvL » Thu Feb 07, 2019 7:31 am
Yes but “appropriate” is not well defined for eigenmodes. You can just scale by maximum value, for example: scale=0.01*max_coord_range/max_disp.
HarryvL
Postby HarryvL » Thu Feb 07, 2019 7:39 am
And if you want to show numerical values you could scale to a maximum of 1.0
bernd
Postby bernd » Thu Feb 07, 2019 7:47 am
ATM they are scaled to the mesh geometry (longest span in main directions.) on result import!
My idea is let the user decide how they should be scaled. Thus I would not scale them at all during result reading of frd file. This would mean in the result obj are exact the values from the frd file.
HarryvL
Postby HarryvL » Thu Feb 07, 2019 10:00 am
Yes that would be an option. I never checked, but would presume that eigenvectors get normalised in Calculix before export. At least that’s how I used to program it. Either normalize on the maximum element or on length. Let’s assume it is on maximum element for a moment. In that case the maximum imported value would be 1, irrespective of length units used. So what is displayed (before user scaling) maybe tiny (if the user built the model in say thousands of millimeters) or huge (if he/she did it in fractions of a kilometer). I therefore think it would be smarter to pre-scale as (for example) scale=0.01*model_range/max_disp. Then what is shown before user intervention is independent of units used.
bernd
Postby bernd » Thu Feb 07, 2019 10:19 am
thanks very much harry. I will do some tests with some frequency analysises.
PrzemoF
Postby PrzemoF » Thu Feb 07, 2019 10:53 am
From my memory, so be careful: the displacement doesn't match anything in the real world. So the exact values from the frd file are not that important. Again, if I remember correctly it was scaled to show some displacement to the user and I didn't really care what's the scale because the displacement has no translation to the real world displacement. Unfortunately I can't find that information right now (I'll keep searching for it).
That comment:
                # Allow for max displacement to be 0.1% of the span
                # FIXME - add to Preferences
was to remind me to allow user to define the displacement in Preferences, but it never happened..
I guess not scaling on import and adding scale to Preferences would be a perfect solution.
Edit: Found it! Take a look at this post: https://forum.freecadweb.org/viewtopic. ... 189#p98162
cron
