GMSH for compound
HarryvL
GMSH for compound
Postby HarryvL » Mon Feb 25, 2019 9:32 pm
Hi, I am trying to create solids with contacting faces. The meshes at the contacts need to line up but the nodes need to be duplicated. It worked Ok for the simple case of 2 stacked blocks combined in a Compound, but not for the example below. I could do with some help from the GMSH gurus.
I tried the following methods. In all cases I use GMSH option Coherence Mesh FALSE:
Type..........................................|Mesh............|Nodes
Compound without gap..........................|Mesh not aligned|Some nodes connected
Compound with gap.............................|Mesh not aligned|Nodes fully disconnected
Boolean Fragments with gap....................|Mesh not aligned|Nodes fully disconnected
Boolean Fragments without gap (mode STANDARD).|Mesh Aligned....|Nodes connected
Boolean Fragments without gap (mode SPLIT)....|Mesh Aligned....|Nodes connected
Boolean Fragments without gap (mode COMPSOLID)|Mesh Aligned....|Nodes connected
None of them give the desired result, i.e. an aligned mesh with duplicated nodes.
Is there a way to achieve this? Perhaps by specifying a physical surface at the interface between the solids of a BooleanFragments object? If so, is there a way to automatically generate physical surfaces at all faces of the solids in a BooleanFragments object?
Exploded view shows meshes are not aligned in a Compound with gap (same in BooleanFragments with gap):
square axle compound.png (198.29 KiB) Viewed 687 times
square axle compound.FCStd
(54.69 KiB) Downloaded 12 times
bernd
Re: GMSH for compound
Postby bernd » Thu Feb 28, 2019 2:13 pm
this is what you would like to have? Am I right?
notconnected.FCStd
(121.7 KiB) Downloaded 14 times
bernd
Postby bernd » Thu Feb 28, 2019 2:18 pm
strange, it does not work for your geometry ...
square axle compound_BHA.FCStd
(135.74 KiB) Downloaded 11 times
bernd
Postby bernd » Thu Feb 28, 2019 2:19 pm
Ahh what I did. Use the exported brep, opened gmsh gui just mesh it 1D, 2D, 3D exported as unv and it was not connected.
Bernd
bernd
Postby bernd » Thu Feb 28, 2019 2:24 pm
BTW: His has to work without a gap. A gap is not an option on a complicated geometry IMHO.
Damn suff, two years ago, I spent hours and hours to connect them and now we need tho other one ... Where is this smily which bangs his head on a wall ...
HarryvL
Postby HarryvL » Thu Feb 28, 2019 3:52 pm
notconnected.FCStd
Yes and the elements on both faces need to line up (so same meshing of the faces)
HarryvL
Postby HarryvL » Thu Feb 28, 2019 3:53 pm
Exactly !! That’s what I am trying to achieve. Duplicated faces and nodes but with the same coordinates.
HarryvL
Postby HarryvL » Thu Feb 28, 2019 3:55 pm
Bernd
Thanks! I will give it a try. If you explode the view by exaggerating deformation of the decoupled mesh do the element on the decoupled meshes line up?
Walgri
Postby Walgri » Thu Feb 28, 2019 4:42 pm
Hi, not sure if this can be of any help, but when I need a point to be present in the generated nodes on a surface I use the Point | Curve { expression-list } In Surface { expression }; command. Maybe in this way, once the first of the two mating surfaces is meshed, GMSH can be forced to insert new nodes on the second mating surface at the same coordinates of the first one.
But AFAIK this won't prevent GMSH to eventually generate also more other nodes, or a different connectivity between nodes, on the second surface. So the second surface may end up with more nodes than the first and most likely elements won't line up.
HarryvL
Postby HarryvL » Thu Feb 28, 2019 6:48 pm
I need to know for sure that duplicate (twin) nodes and element faces line up to make the interface elements work. If this is not guaranteed then I need to duplicate nodes and reconnect volume elements in FreeCAD. I made a start with that, but it means I need to overcome a number of challenges.
