restrict constraint on shells
Jee-Bee
Post by Jee-Bee »
I have a FEM issue. Calculix complains about wrong boundary conditions on shells. But i'have no idea how to lock sertain restrictions.
Below the code:
*ERROR: in gen3dboun: node           76  does not
         belong to a beam nor shell
         element and consequently has no
         rotational degrees of freedom.
         This may be caused by applying
         a local coordinate system to a
         node in which a rotational boundary
         conditions is defined. In CalculiX
         this is not allowed.
This is my FC version
OS: Windows 7
Version: 0.18.15711 (Git)
Hash: 5caae5f430237a73cd17e283d45b3ac9ab005feb
Python version: 3.6.6
Qt version: 5.6.2
and last also a my model:
test_2D_GMSH_vibration_example.FCStd
(134.86 KiB) Downloaded 24 times
fandaL
Re: restrict constraint on shells
Post by fandaL »
I get the same error from ccx with your mesh. It contains linear quad4 elements and quadratic tria6 elements which means mid-nodes of tria cannot be connected to quads. But it is not the object of the error.
It seems that nodes was written to the inp file including mid-nodes of original quadratic quad8 elements but they are not used since quad4 elements in the inp file are linear, so some of constrained nodes are orphans (thus missing rotation DOFs for ccx and giving that error).
And strange is also that nodes highlighted by cgx (FemConstraintFixed node set) are only from one of the edges selected in FC gui as constraint edge. Other nodes are like from wrong edges.
For me everything work if I remesh your mesh (no settings changed). I get a mesh with tria6 elements and ccx gives results.
OS: Windows 7
Version: 0.18.16028 (Git)
Hash: 9079de7516eca945587e18f6076ec74eb7bd043c
Python version: 2.7.14
OCC version: 7.2.0
Locale: Czech/CzechRepublic (cs_CZ)
bernd
Post by bernd »
wow great debugging ... I am not yet sure how to handle such cases. BTW: how did you get such «funny»mesh?
Jee-Bee
Post by Jee-Bee »
First how do you show the node points? I don't see them so i didn't now there were two types of elements involved.
How i created the funny mesh? no clue. I would expect the used settings are visible in my model.
In "Mesh by GMSH" i select as model 2D model and max_mesh_size =10 AND min_mesh_size=1.
that's it.
What i figured out yesterday (but i didn't had the time to post it) when i edit the inp-file and remove the fixed constraints 4,5,6 it work out too.
Based on that i would request to extend the fixed constraints that it have te options to limit (certain) rotations or directions.
If needed i start a new topic for that and try to create some example
fandaL
Post by fandaL »
Jee-Bee wrote: Sat Mar 09, 2019 9:20 am First how do you show the node points?
Look at View parameter of the mesh object: "Display Mode".
Jee-Bee wrote: Sat Mar 09, 2019 9:20 am How i created the funny mesh? no clue. I would expect the used settings are visible in my model.
that's it.
You can get the wrong mesh by using mesh parameter "Recombine = True". If I understand it correctly it will combine each two triangles to one quad element if possible. For more complicated geometries some triangles will remain so I would expect combination of quad8 and tria6, but currently we have a mix of tria6 and quad4 elements.
If I open the wrong mesh Facebinder_Mesh_TmpGmsh.unv in the gmsh (the file generated by gmsh and used to import to FC) and display nodes I see nodes of quadratic triangles and edges but linear quads.
But if I open the geo file in gmsh shape2mesh.geo (generated by FC to give commands to gmsh) than gmsh generates correct fully quadratic mesh. So I see the problem that gmsh exports quad4 elements instead of quad8 elements to the unv file.
I don't know FC code inside too much, so I only guess that nodes from edge elements are used to apply constraints (including mid-nodes), but here we don't write edge elements to the inp file and don't have mid-nodes on linear quads, so dummy nodes are passed to ccx.
