Question concerning the VTK file format
bernd
Re: Question concerning the VTK file format
Postby bernd » Tue Mar 12, 2019 6:54 pm
ok here the Python code for exporting on windows ...
doc = FreeCAD.open(FreeCAD.ConfigGet("AppHomePath") + 'data/examples/FemCalculixCantilever3D.FCStd')
doc.Box_Mesh.FemMesh.write("C:/Users/Public/mesh.vtk")
import Fem
Fem.writeResult( "C:/Users/Public/result_and_resultmesh.vtk", doc.CalculiX_static_results)
with the gui it works a follows ...
- open 3D FEM cantilever
- select the mesh object "Box_Mesh" --> export to "FEM mesh formats" --> mesh.vtk --> exports the mesh into a vtk mesh
- if you select the result_mesh and do the same than the result mesh will be exported only, no results
- select the result object "CalculiX_static_results" --> export to "FEM result VTK" --> result_and_resultmesh.vtk --> exports the result_mesh and the results into a vtk file
bernd
bernd
Postby bernd » Tue Mar 12, 2019 6:57 pm
issue #3628 is an issue for export vtk to vtk
thschrader
Postby thschrader » Tue Mar 12, 2019 9:11 pm
Ok, a little calculation.
Bernd/Uwe, can you tell me which part of the model tree I can export to vtk-format?
I still use the the frd-to-vtk-tool from user mamah.
https://forum.freecadweb.org/viewtopic. ... 4&start=10
bernd
Postby bernd » Tue Mar 12, 2019 10:06 pm
uwestoehr
Postby uwestoehr » Wed Mar 13, 2019 12:03 am
Here I see the problem that could be avoided:
- I selected "CalculiX_static_results" but did not choose "FEM result VTK" but "FEM mesh formats"
Yes, a result is no mesh, however in the export dialog these 2 entries are above each other so one can quickly make a mistake. The problem is that the user don't get any info. He exports but nothing will in fact be exported. No file will be written and he doesn't get info that nothing was output.
If possible, if the user selected a result object either the export to mesh option won't be available or he gets the info that the selection is not compatible with the selected object
Postby Kunda1 » Thu Mar 14, 2019 3:32 pm
Good point from usability standpoint.
bernd
Postby bernd » Thu Mar 14, 2019 10:15 pm
feel free to make an issue and assign it to me
uwestoehr
Postby uwestoehr » Thu Mar 14, 2019 11:11 pm
Done: issue #3906
