Burst Pressure of a thick-walled Sphere
HarryvL
Re: Burst Pressure of a thick-walled Sphere
Post by HarryvL »
... and now it also becomes important to look at the plastic strain to judge potential rupture of the steel.
HarryvL
Post by HarryvL »
HoWil wrote: Sun Apr 14, 2019 5:36 am
HarryvL wrote: Sat Apr 13, 2019 12:10 pm So in this case fcFEM over-predicts theory by 0.045% ... not bad ;)
Is it possible to share your model?
Both uploaded here: https://github.com/HarryvL/fcFEM/tree/m ... eCAD_Files
HoWil
Post by HoWil »
HarryvL wrote: Sun Apr 14, 2019 1:40 pm
Thanks.
HoWil
Post by HoWil »
-alex- wrote: Sun Apr 14, 2019 8:20 am FYI I remember now, I saw this kind of routine in Freelem software. After installing the soft, for the first run, a stress test routine was testing 126 typical study cases. Then the soft told to the user a result "126/126" tests succed. Something like that.
http://www.freelem.com/qualif/index.htm
Hi alex, Hi HarryvL,
Hope such a testing can be part of this years Gsoc .... please see also https://forum.freecadweb.org/viewtopic. ... 28#p299023
ElmerFEM also includes tones of test-cases which could be used for comparison.... https://github.com/ElmerCSC/elmerfem/tr ... /fem/tests or http://www.nic.funet.fi/index/elmer/doc ... nonGUI.pdf
BR,
Howil
bernd
Post by bernd »
HoWil wrote: Mon Apr 15, 2019 9:48 am Hope such a testing can be part of this years Gsoc ....
let's say improved. ;) Because we gone have some tests already. Not as much as there should be but there are a few ...
- start FreeCAD
- run code ...
import Test, TestFem
Test.runTestsFromModule(TestFem)
See https://github.com/FreeCAD/FreeCAD/blob ... TestFem.py for some help
We even have real test cases for whole models, ok just one but we have ... https://github.com/FreeCAD/FreeCAD/blob ... manager.py This one is not yet a verification test. But as harry stated in oofem I made the examples verification tests too. See https://github.com/berndhahnebach/FreeC ... e07a9a11b0
Locally I have a few more, but did not have the time to push the to master.
BTW: harry, cool stuff :) Just for my understanding. By the use of calculix an non linear material we should get the same results, shouldn't we?
HarryvL
Post by HarryvL »
bernd wrote: Mon Apr 15, 2019 10:16 am ... just for my understanding. By the use of calculix an non linear material we should get the same results, shouldn't we?
In principle yes, but Calculix cannot handle plastic collapse with load control (yet). I asked Guido a year ago and he said it was on his TODO list, where (I think) it still is. One of the reasons I decided to start something that is fully in our control.
HarryvL
Post by HarryvL »
Fans of unit testing may enjoy this one. The work I did on optimising band width has introduced an error in boundary conditions.
I now know that I have broken the two golden rules of profiling and optimizing:
1) Don't optimize too early - I did, making changes harder to manage
2) Don't assume you know where the bottlenecks are - I did, having spent a lot of time on band-width reduction, only to find that the bottleneck was in stress updating
I have now included cProfile in my code to tell me where the bottlenecks are :D (een ezel, in 't gemeen, stoot zich niet twee keer aan dezelfde steen)
HarryvL
Post by HarryvL »
Fixed:
HarryvL
Post by HarryvL »
HarryvL wrote: Sun Apr 14, 2019 1:19 pm ... and now it also becomes important to look at the plastic strain to judge potential rupture of the steel.
With the critical plastic strain utility (https://forum.freecadweb.org/viewtopic. ... 93#p303392) it is now possible to judge the potential of ductile fracture for both designs.
The steel used for the pressure vessel is high strength steel and the ductility in the SMCS model should be chosen accordingly. In the absence of actual data I select alpha=1.0, which is at the lower end of what is reported in literature. However, without specific material data this choice may be unconservative !
Like in the case of the plate with hole, I determine the critical plastic strain ratio at plastic collapse:
The ciritical plastic strain ratio for the sphere is well below the value of 1.0 at which ductile fracture may occur.
However, the results for the hollow cube are quite different:
Now the critical plastic strain ratio far exceeds what is acceptable and ductile fracture is likely well before the ultimate load is reached.
Close inspection of the results shows that the stress triaxiality in the cube (T=3.7) is much higher than that in the sphere (T=0.7), leading to brittle behaviour.
bernd
Post by bernd »
BTW: Harry, How do you do the diagramms?
