Result mesh single element/node picking and inspection
bernd
Re: Result mesh single element/node picking and inspection
Postby bernd » Tue Apr 23, 2019 2:39 pm
Damn it is even more complicated ... Data at point seams to use the FreeCAD FE mesh to select the point. But we gone have two FE meshes, the analysis mesh and the result mesh. You should for sure make the analysis mesh not visible.
Mhh I need to play with this too. I have not used the tool for ages ...
Walgri
Postby Walgri » Tue Apr 23, 2019 2:50 pm
The analysis mesh is made visibile when I click on the Select Point button.
bernd
Postby bernd » Tue Apr 23, 2019 3:08 pm
Yes this is what I mean with ...
... Data at point seams to use the FreeCAD FE mesh to select the point ...
This is the code which is run on button "Select Point"
>>> for amesh in App.activeDocument().Objects:
>>>     if "Mesh" in amesh.TypeId:
>>>          aparttoshow = amesh.Name.replace("_Mesh","")
>>>          for apart in App.activeDocument().Objects:
>>>              if aparttoshow == apart.Name:
>>>                  apart.ViewObject.Visibility = True
As said there might be some problem with DataAtPoint ...
