FEM post processing pipeline with scalar value export .obj .stl
Figyi
Post by Figyi »
Hi There! Is possible the post-process scalarclip convert or export to stl, obj, or other mesh?
https://drive.google.com/file/d/1L93rn6 ... p=drivesdk
Best Regards!
Re: FEM post processing pipeline with scalar value export .obj .stl
Hi Figyi, welcome to the forum.
Isn't that the common non FEM export of objects to STL?
Besides, you should use a screenshot tool, they are readily available for all OSs. Those screenshot images are usually of perfect quality while being much smaller than an image of a modern camera or smartphone.
If you want to show 3D view only you even can use the FreeCAD builtin tool Menu->Tools->Save picture.
The images can be attached directly to the post, which makes it easier to read. It is appreciated if you crop the image to what you really want to show.
UR_
Post by UR_ »
Sorry, I think some workarounds are necessary to achieve this, :(
(because FreeCAD FEM has no surface filter and .stl is a surface only file format)
Workflow (cantilever 3D example from FreeCAD's start page)
- after calculation by ccx you get among others the result file: Box_Mesh.frd
- now this is converted to Box_Mesh-mmh.vtk using this utility: https://forum.freecadweb.org/viewtopic. ... 10#p184850
- now this vtk-file is loaded into Paraview and your clip filter is applied
- additionally a surface filter is needed to delete inner geometry
Annotation 2019-05-09 082859.png (8.22 KiB) Viewed 1751 times
- saving as stl delivers desired file
canticlip.stl
(131.12 KiB) Downloaded 36 times
Annotation 2019-05-09 083607.png (23.29 KiB) Viewed 1751 times
Annotation 2019-05-09 083929.png (105.28 KiB) Viewed 1751 times
ickby
Post by ickby »
That would be a nice addition to the freecad postprocessing pipeline, it should be pretty easy to implement.
bernd
Post by bernd »
ickby wrote: Thu May 09, 2019 7:29 am That would be a nice addition to the freecad postprocessing pipeline, it should be pretty easy to implement.
depends. If one knows C++ is should be pretty easy, but since ATM there is no access to the pipline data by Python this is possible in C++ only AFAIK.
It is like the export of a vtk pipeline to vtk. This needs to be implemented in C++ too.
bernd
Post by bernd »
UR_ wrote: Thu May 09, 2019 6:46 am - now this is converted to Box_Mesh-mmh.vtk using this utility: [url]https://forum.freecadweb.org/viewtopic. ... it=mmh.vtk&
This could be done from within FreeCAD too. AFAIK FreeCAD 0.19 exports all needed results to vtk, or do you miss some results if they are exported from FreeCAD to vtk.
Post by Kunda1 »
bernd wrote: Thu May 09, 2019 10:43 am
Shall we open a FR?
UR_
Post by UR_ »
bernd wrote: Thu May 09, 2019 10:45 am ... AFAIK FreeCAD 0.19 exports all needed results to vtk...
:ok_hand:
ickby
Post by ickby »
Shall we open a FR?
Actually I think the feature request should be to expose the vtk pipeline to python. I never did id as VTK was always build with Qt5 and FreeCAD with Qt4, hence "import vtk" crashed, but now it should work with qt5 build (it does with the windows installer of 0.18.1) and hence making it python extensible should be doable... and could enhance development of the post-processing significantly!
bernd
Post by bernd »
ickby wrote: Thu May 09, 2019 11:36 am
Shall we open a FR?
+1
Just for my understanding. This would mean we gone use the python bindings of VTK and do not write our own ones like for SMESH.
