This has gotten fixed, at least on FreeBSD: https://www.freecadweb.org/tracker/view ... 984#c13224
I've checked at least some of the Path and FEM functions that create new dialogs, and so far everything has worked.
What do you mean? master is at 17068, 16117 is 0.18.2
Don't know if it was incorporated in master yet. Hope it helps.denverh wrote: ↑Mon Jun 17, 2019 12:46 pmThis has gotten fixed, at least on FreeBSD: https://www.freecadweb.org/tracker/view ... 984#c13224
[ 70%] Linking CXX shared library ../../lib/libFreeCADGui.so !1347
/usr/bin/ld: CMakeFiles/FreeCADGui.dir/WidgetFactory.cpp.o: in function `convertWrapperToQuantity(PySide::PyObjectWrapper const&)':
WidgetFactory.cpp:(.text+0xcd): undefined reference to `PySide::PyObjectWrapper::operator _object*() const'
/usr/bin/ld: CMakeFiles/FreeCADGui.dir/WidgetFactory.cpp.o: in function `QtMetaTypePrivate::QMetaTypeFunctionHelper<PySide::PyObjectWrapper, true>::Construct(void*, void const*)':
WidgetFactory.cpp:(.text._ZN17QtMetaTypePrivate23QMetaTypeFunctionHelperIN6PySide15PyObjectWrapperELb1EE9ConstructEPvPKv[_ZN17QtMetaTypePrivate23QMetaTypeFunctionHelperIN6PySide15PyObjectWrapperELb1EE9ConstructEPvPKv]+0xa): undefined reference to `PySide::PyObjectWrapper::PyObjectWrapper(PySide::PyObjectWrapper const&)'
/usr/bin/ld: WidgetFactory.cpp:(.text._ZN17QtMetaTypePrivate23QMetaTypeFunctionHelperIN6PySide15PyObjectWrapperELb1EE9ConstructEPvPKv[_ZN17QtMetaTypePrivate23QMetaTypeFunctionHelperIN6PySide15PyObjectWrapperELb1EE9ConstructEPvPKv]+0x19): undefined reference to `PySide::PyObjectWrapper::PyObjectWrapper()'
/usr/bin/ld: CMakeFiles/FreeCADGui.dir/WidgetFactory.cpp.o: in function `QtMetaTypePrivate::QMetaTypeFunctionHelper<PySide::PyObjectWrapper, true>::Destruct(void*)':
WidgetFactory.cpp:(.text._ZN17QtMetaTypePrivate23QMetaTypeFunctionHelperIN6PySide15PyObjectWrapperELb1EE8DestructEPv[_ZN17QtMetaTypePrivate23QMetaTypeFunctionHelperIN6PySide15PyObjectWrapperELb1EE8DestructEPv]+0x1): undefined reference to
`PySide::PyObjectWrapper::~PyObjectWrapper()'
collect2: Fehler: ld gab 1 als Ende-Status zurück
make[2]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/build.make:5595: lib/libFreeCADGui.so] Fehler 1
make[1]: *** [CMakeFiles/Makefile2:6081: src/Gui/CMakeFiles/FreeCADGui.dir/all] Fehler 2
make: *** [Makefile:130: all] Fehler 2
like Kunda1 said:
I had some progress on building on Manjaro. My output of the variables after getting the properties from the patch:Kunda1 wrote: ↑Fri Jun 21, 2019 1:08 pmhttps://www.freecadweb.org/wiki/Source_ ... es_via_git
git apply [patch-name].patch
SHIBOKEN_INCLUDE_DIR: /usr/include/shiboken2/usr/include/python3.7m
SHIBOKEN_LIBRARY: /usr/lib/libshiboken2.cpython-37m-x86_64-linux-gnu.so.5.12.3
PYSIDE_INCLUDE_DIR: /usr/include/PySide2
PYSIDE_LIBRARY:
