Reaction forces
mthulson
Reaction forces
Post by mthulson »
I just started using the FreeCAD FEM module and managed to analyze a part I've designed. I fixed one face and constrained the displacement of an edge. The results look good, but I need reaction forces at the edge I've displaced, and that's not included in the results. I found a discussion that sounds like what I need (https://forum.freecadweb.org/viewtopic. ... =4&t=20664), but unfortunately I don't understand how to implement the suggestions. Can anyone help and/or point me toward a tutorial designed for idiots that will help me figure this out?
PrzemoF
Re: Reaction forces
Post by PrzemoF »
@bernd: is it something that could be done easily or there is some coding required?
UR_
Re: Reaction forces
Post by UR_ »
I think an appropriate example can be found here:
https://forum.freecadweb.org/viewtopic. ... on#p167047
Example file is some days old, perhaps updating is necessary :?
EDIT: updated files
Version: 0.19.16921 (Git)
Hash: 39e748229e67fa93e924e355c0ce0897c870d756
Python version: 3.6.6
Qt version: 5.6.2
Ringauge.FCStd
(812.01 KiB) Downloaded 51 times
Re: Reaction forces
Moved to FEM.
bernd
Re: Reaction forces
Post by bernd »
would be a nice addition to FEM ... has been a feature request for years ... issue #2934
bernd
Re: Reaction forces
Post by bernd »
How about adding an option to create reaction forces for every restrained boundary condition? This would be easy to implement. Still one would need to open the dat file anyway to get the forces but it is no longer needed to edit the input file.
bernd
mthulson
Re: Reaction forces
Post by mthulson »
I'm afraid I'm missing something fundamental (and probably obvious to everyone but me). I gather that .inp, .dat, and/or .frd files define the problem and output the results. I set the problem up and solved it using CalculiX in the FreeCAD FEM module, but can't find .inp, .dat, or .frd files anywhere.
What am I missing? Sorry to be so obtuse.
UR_
Re: Reaction forces
Post by UR_ »
mthulson wrote: Thu Jun 06, 2019 3:45 pm ... but can't find .inp, .dat, or .frd files anywhere ...
Please have look at Edit->Preferences->FEM->General
Annotation 2019-06-06 194711.png (36.12 KiB) Viewed 2299 times
bernd
Re: Reaction forces
Post by bernd »
activate on view -> panels -> report view. Run the analysis, there will be printed a lot in report view, one of the last lines is the path to the dat file ...
mthulson
Re: Reaction forces
Post by mthulson »
I figured out that if I double click on CalculiXccxTools in the tree view, I get a Mechanical Analysis dialog where I can set the working directory, then write the .inp file, then edit it, then run CalculiX. When I add the lines in the example from UR_, the reaction loads are included in the .dat file. Previously, I was using the "Runs the calculations for the selected solver" button.
For some reason, setting the working directory in edit -> preferences -> FEM didn't seem to work. When I open the report view as bernd suggested, I see "FEM preferences working dir is not set, the solver working directory is used."
Anyway, it's working now. Thanks for the help!
