hi.i m a student engineering. i m trying to do a flutter analysis (sol145) post the normal modes analisys.
i m following a tutorial, but i m really blocked to the creation of splines. i m using patran2019 but i can follow tutorial cuz i m not able to see that in my version patran. how can i solve?
tutorial:
5. Define Splines
Flight Loads/Aeroelasticity/Aero-Structure Coupling…
Action: Create
Object: Surface
Method: General
Spline Name
spline
Structural Points
Nodes Groups
Select Groups…
Existing Groups: default_group
Close
Aero Boxes
Elements Surface
Existing Surface…
Existing Surfaces: aero
Close
Apply
me: aerostructure coupling
create
surface spline
tipy: infinite plate (and there isnt method)
select structural nodes
select aero grids
input data.
Flutter Analisys (sol145) Nastran/Patran/Flightloads
Re: Flutter Analisys (sol145) Nastran/Patran/Flightloads
Do you use nastran in combination with FreeCAD??
nono.. i use patran (preproc) and nastran for this flutter analysis. why
Quite simple the Forum is all about FreeCAD.
FreeCAD have a small FEM module but based on Calulix , Z88, Elmer, openFOAM as main solvers. Don't know if anybody here as some experience with Nastran
