mesh region
ElMastro
Re: mesh region
Postby ElMastro » Fri Jun 28, 2019 10:31 am
You are right, what I intended to say is that I use a launcher for calculix. The program I use is this
http://calculixforwin.blogspot.com/2015 ... ncher.html
I know I should probably do it with gmsh and a text editor, but I'm not capable.
bernd
Re: mesh region
Postby bernd » Fri Jun 28, 2019 1:39 pm
No you are on the right track, either FreeCAD export or CalculiX luncher import did something wrong. I would like to know who of both!
ElMastro
Re: mesh region
Postby ElMastro » Mon Jul 01, 2019 4:38 pm
I can add some information:
When the mesh is made with salome meca in *.unv file format and it's imported in calculix launcher, it works. The output from sheel of Freecad is
FreeCAD 0.19, Libs: 0.19R17105 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
connect failed: File o directory non esistente
Active analysis found: Analysis
TypeError: Can't call meta function because I have no idea how to handle Base::Quantity
We are going to start Gmsh FEM mesh run!
  Part to mesh: Name --> Box,  Label --> Cubo, ShapeType --> Solid
  CharacteristicLengthMax: 1e+22
  CharacteristicLengthMin: 0.0
  ElementOrder: 2
  ElementDimension: 3
  /tmp/Box_Geometry.brep
  /tmp/Box_Mesh_TmpGmsh.unv
  /tmp/shape2mesh.geo
  /usr/bin/gmsh
  Group meshing for analysis.
  The Part should have a pretty new FEM mesh!
Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid
Single click on a Solid, Face, Edge, Vertex will add it to the list!
selection: Solid  Box  Face3
selection: Solid  Box  Face4
and in python shell
Python 3.7.3 (default, Jun 24 2019, 04:54:02)
[GCC 9.1.0] on linux
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> App.newDocument("Senza nome")
>>> App.setActiveDocument("Senza_nome")
>>> App.ActiveDocument=App.getDocument("Senza_nome")
>>> Gui.ActiveDocument=Gui.getDocument("Senza_nome")
>>> Gui.activeDocument().activeView().viewDefaultOrientation()
>>> Gui.activateWorkbench("PartWorkbench")
>>> App.ActiveDocument.addObject("Part::Box","Box")
>>> App.ActiveDocument.ActiveObject.Label = "Cubo"
>>> App.ActiveDocument.recompute()
>>> Gui.SendMsgToActiveView("ViewFit")
>>> Gui.activateWorkbench("FemWorkbench")
>>> import FemGui
>>> import ObjectsFem
>>> ObjectsFem.makeAnalysis(FreeCAD.ActiveDocument, 'Analysis')
>>> FemGui.setActiveAnalysis(FreeCAD.ActiveDocument.ActiveObject)
>>> ObjectsFem.makeSolverCalculixCcxTools(FreeCAD.ActiveDocument)
>>> FemGui.getActiveAnalysis().addObject(FreeCAD.ActiveDocument.ActiveObject)
>>> ObjectsFem.makeMeshGmsh(FreeCAD.ActiveDocument, 'FEMMeshGmsh')
>>> FreeCAD.ActiveDocument.ActiveObject.Part = FreeCAD.ActiveDocument.Box
>>> FreeCADGui.ActiveDocument.setEdit(FreeCAD.ActiveDocument.ActiveObject.Name)
>>> ObjectsFem.makeMeshGroup(FreeCAD.ActiveDocument, FreeCAD.ActiveDocument.FEMMeshGmsh)
>>> __objs__=[]
>>> __objs__.append(FreeCAD.getDocument("Senza_nome").getObject("FEMMeshGmsh"))
>>> __objs__.append(FreeCAD.getDocument("Senza_nome").getObject("FEMMeshGroup001"))
>>> __objs__.append(FreeCAD.getDocument("Senza_nome").getObject("FEMMeshGroup"))
>>> import Fem
>>> Fem.export(__objs__,u"/tmp/Mesh.inp")
>>> del __objs__
ON calculix launcher, when after mesh load, the output in shell is , after the numbers describing the mesh, this
2242 4.290024e+00 8.420360e+00 8.182291e+00
2243 4.076004e+00 1.722280e+00 1.723874e+00
cgnodes_mode: total nodes 2243
Center of gravity 5.020611e+00 4.989055e+00 4.996157e+00
VOLUME:0.000000  MASS:0.000000e+00 CENTER OF GRAVITY: -nan -nan -nan
pre_area2() f=0 !
cgnodes mode
 please wait for 'ready'
 write abaqus data
 file Eall.msh opened
 ready
cgnodes_mode: total nodes 0
Center of gravity -nan -nan -nan
ERROR: type:12 of elem:1 not known. Interrupt
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file +B32R.msh opened
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file +S6.msh opened
 ready
ERROR: type:8 of elem:73 not known. Interrupt
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file +C3D10.msh opened
 ready
VOLUME:1000.000000 CENTER OF GRAVITY: 5.000000 5.000000 5.000000
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file Eedges.msh opened
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file Efaces.msh opened
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file Evolumes.msh opened
 ready
all.fbd opened
 write fbd
 ready
bernd
Re: mesh region
Postby bernd » Mon Jul 01, 2019 5:12 pm
ahh the unv exporter off FreeCAD uses the same code base as salome, means try to use unv exported from FreeCAD!
ElMastro
Re: mesh region
Postby ElMastro » Tue Jul 02, 2019 9:56 am
I've tried it now. output of Freecad is the same, Calculix Launcher writes
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file C3D10.msh opened
 ready
all.fbd opened
 write fbd
 ready
on a Linux machine, nodename archbang, release 5.1.10-2-ck, version #1 SMP PREEMPT Sun Jun 16 23:03:48 CEST 2019, machine x86_64
parameters:3 arguments:2
/tmp/cgxcmd opened
 reading file
*  read ccx input                                   4.4.2002 wi              *
* -only free-format is supported. fixed format might cause a prg-crash.      *
 2243 nodes reallocated
 1192 elements reallocated
 ready
WRITEINONE command:
path = `'
exec SEND ALL ABQ
 write abaqus data
 file all.msh opened
 ready
execute SEND ALL ABQ NAM
 write file: Nall.nam
 ready
 write file: Eall.nam
 ready
 write file: C3D10.nam
 ready
 write file: all.nam
 ready
 ready
execute SEND ALL ABQ SUR
 write file: all.sur
 ready
 ready
current dir = /tmp
fullname = allinone.inp
copy all.msh ->
copy C3D10.nam ->
execute  C3D10 abq sur
 write file: C3D10.sur
 ready
 ready
copy C3D10.sur ->
copy all.sur ->
 ready
AREA:600.000000  CENTER OF GRAVITY: 5.000000 5.000000 5.000000
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
all.fbd opened
 write fbd
 ready
Which is pretty similar to me. As soon as I have enough time I'll try to open it in Salome to understand what differs
bernd
Re: mesh region
Postby bernd » Tue Jul 02, 2019 10:13 am
What does the output mean? Does it work or does it not work?
If not, would you try the following:
- Take the unv exported with salome (which works with calculix luncher)
- open the unv in FreeCAD, a fe mesh object (FEM module mesh object) will be created
- export this fe mesh object (FEM module mesh object) to unv
- use the exported unv in CalculiX luncher
ElMastro
Re: mesh region
Postby ElMastro » Tue Jul 02, 2019 10:23 am
Salome doesn't see the groups opening the mesh. On the icon there is also an exclamation point, probably it means the mesh is in error.
Opening a mesh made with Salome calculix open another terminal, and the output in shell is
cgnodes_mode: total nodes 636907
Center of gravity 3.056163e+01 9.653511e+00 3.982104e+00
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
VOLUME:224816.470030 CENTER OF GRAVITY: 30.005978 10.000425 41.157458
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file +C3D4.msh opened
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file FissoF4.msh opened
 ready
VOLUME:809.024587 CENTER OF GRAVITY: 29.185095 10.948783 -103.465230
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file FissoF3.msh opened
 ready
VOLUME:756.810693 CENTER OF GRAVITY: 31.403979 9.327305 -103.451363
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file FissoF2.msh opened
 ready
VOLUME:406.648373 CENTER OF GRAVITY: 29.594275 9.744781 -103.424548
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file FissoF1.msh opened
 ready
VOLUME:388.703321 CENTER OF GRAVITY: 27.414586 10.160765 -103.696433
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file ForzanteF4.msh opened
 ready
VOLUME:629.091427 CENTER OF GRAVITY: 32.336237 9.716446 157.639124
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file ForzanteF3.msh opened
 ready
VOLUME:688.551957 CENTER OF GRAVITY: 28.311270 10.661156 157.635470
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file ForzanteF2.msh opened
 ready
VOLUME:423.972928 CENTER OF GRAVITY: 32.845351 11.707300 157.738945
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file ForzanteF1.msh opened
 ready
VOLUME:440.764818 CENTER OF GRAVITY: 27.393056 6.839269 157.551603
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file C3D4.msh opened
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file Fisso.msh opened
 ready
1 -1.000000e+00 0.000000e+00 -1.050000e+02
2 6.100000e+01 0.000000e+00 -1.050000e+02
3 -1.000000e+00 2.000000e+01 -1.050000e+02
4 6.100000e+01 2.000000e+01 -1.050000e+02
5073 -1.000000e+00 5.000000e+00 -1.050000e+02
5074 -1.000000e+00 1.000000e+01 -1.050000e+02
5075 -1.000000e+00 1.500000e+01 -1.050000e+02
5076 4.636364e+00 2.000000e+01 -1.050000e+02
5077 1.027273e+01 2.000000e+01 -1.050000e+02
5078 1.590909e+01 2.000000e+01 -1.050000e+02
5079 2.154545e+01 2.000000e+01 -1.050000e+02
5080 2.718182e+01 2.000000e+01 -1.050000e+02
5081 3.281818e+01 2.000000e+01 -1.050000e+02
5082 3.845455e+01 2.000000e+01 -1.050000e+02
5083 4.409091e+01 2.000000e+01 -1.050000e+02
5084 4.972727e+01 2.000000e+01 -1.050000e+02
5085 5.536364e+01 2.000000e+01 -1.050000e+02
5086 6.100000e+01 5.000000e+00 -1.050000e+02
5087 6.100000e+01 1.000000e+01 -1.050000e+02
5088 6.100000e+01 1.500000e+01 -1.050000e+02
5089 4.636364e+00 0.000000e+00 -1.050000e+02
5090 1.027273e+01 0.000000e+00 -1.050000e+02
5091 1.590909e+01 0.000000e+00 -1.050000e+02
5092 2.154545e+01 0.000000e+00 -1.050000e+02
5093 2.718182e+01 0.000000e+00 -1.050000e+02
5094 3.281818e+01 0.000000e+00 -1.050000e+02
5095 3.845455e+01 0.000000e+00 -1.050000e+02
5096 4.409091e+01 0.000000e+00 -1.050000e+02
5097 4.972727e+01 0.000000e+00 -1.050000e+02
5098 5.536364e+01 0.000000e+00 -1.050000e+02
60689 3.542751e+00 6.264414e+00 -1.050000e+02
60690 7.100470e+00 1.558233e+01 -1.050000e+02
60691 1.873131e+01 1.514754e+01 -1.050000e+02
60692 2.999285e+01 1.500136e+01 -1.050000e+02
60693 4.128228e+01 1.479464e+01 -1.050000e+02
60694 5.230066e+01 1.420208e+01 -1.050000e+02
60695 5.709885e+01 1.465613e+01 -1.050000e+02
60696 5.593852e+01 8.468123e+00 -1.050000e+02
60697 7.741770e+00 3.687735e+00 -1.050000e+02
60698 1.263858e+01 5.463665e+00 -1.050000e+02
60699 1.858876e+01 5.153552e+00 -1.050000e+02
60700 2.431364e+01 5.049828e+00 -1.050000e+02
60701 2.995987e+01 5.003955e+00 -1.050000e+02
60702 3.553823e+01 4.942912e+00 -1.050000e+02
60703 4.098317e+01 4.805018e+00 -1.050000e+02
60704 4.599044e+01 4.470735e+00 -1.050000e+02
60705 5.026401e+01 7.570864e+00 -1.050000e+02
60706 4.465662e+00 1.122930e+01 -1.050000e+02
60707 1.309311e+01 1.542062e+01 -1.050000e+02
60708 2.435986e+01 1.504650e+01 -1.050000e+02
60709 3.563162e+01 1.494602e+01 -1.050000e+02
60710 4.693934e+01 1.439888e+01 -1.050000e+02
60711 3.277990e+01 9.973163e+00 -1.050000e+02
60712 1.585208e+01 1.037076e+01 -1.050000e+02
60713 4.404746e+01 9.483704e+00 -1.050000e+02
60714 2.715847e+01 1.003437e+01 -1.050000e+02
60715 3.838972e+01 9.855003e+00 -1.050000e+02
60716 7.837239e+00 7.739776e+00 -1.050000e+02
60717 1.039377e+01 1.121459e+01 -1.050000e+02
60718 2.150532e+01 1.012109e+01 -1.050000e+02
cgnodes_mode: total nodes 60
Center of gravity 2.924100e+01 1.000165e+01 -1.050000e+02
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 file Forzante.msh opened
 ready
114 6.100000e+01 2.000000e+01 1.590000e+02
115 6.100000e+01 0.000000e+00 1.590000e+02
118 -1.000000e+00 2.000000e+01 1.590000e+02
120 -1.000000e+00 0.000000e+00 1.590000e+02
47411 6.100000e+01 5.000000e+00 1.590000e+02
47412 6.100000e+01 1.000000e+01 1.590000e+02
47413 6.100000e+01 1.500000e+01 1.590000e+02
49318 4.636364e+00 2.000000e+01 1.590000e+02
49319 1.027273e+01 2.000000e+01 1.590000e+02
49320 1.590909e+01 2.000000e+01 1.590000e+02
49321 2.154545e+01 2.000000e+01 1.590000e+02
49322 2.718182e+01 2.000000e+01 1.590000e+02
49323 3.281818e+01 2.000000e+01 1.590000e+02
49324 3.845455e+01 2.000000e+01 1.590000e+02
49325 4.409091e+01 2.000000e+01 1.590000e+02
49326 4.972727e+01 2.000000e+01 1.590000e+02
49327 5.536364e+01 2.000000e+01 1.590000e+02
49350 -1.000000e+00 5.000000e+00 1.590000e+02
49351 -1.000000e+00 1.000000e+01 1.590000e+02
49352 -1.000000e+00 1.500000e+01 1.590000e+02
49353 4.636364e+00 0.000000e+00 1.590000e+02
49354 1.027273e+01 0.000000e+00 1.590000e+02
49355 1.590909e+01 0.000000e+00 1.590000e+02
49356 2.154545e+01 0.000000e+00 1.590000e+02
49357 2.718182e+01 0.000000e+00 1.590000e+02
49358 3.281818e+01 0.000000e+00 1.590000e+02
49359 3.845455e+01 0.000000e+00 1.590000e+02
49360 4.409091e+01 0.000000e+00 1.590000e+02
49361 4.972727e+01 0.000000e+00 1.590000e+02
49362 5.536364e+01 0.000000e+00 1.590000e+02
376072 3.425110e+00 7.093141e+00 1.590000e+02
376073 3.426485e+00 1.289526e+01 1.590000e+02
376074 8.386936e+00 1.478263e+01 1.590000e+02
376075 1.361923e+01 1.500353e+01 1.590000e+02
376076 1.899846e+01 1.501554e+01 1.590000e+02
376077 2.449288e+01 1.500957e+01 1.590000e+02
376078 3.005601e+01 1.500513e+01 1.590000e+02
376079 3.565515e+01 1.499974e+01 1.590000e+02
376080 4.126865e+01 1.498644e+01 1.590000e+02
376081 4.684328e+01 1.496186e+01 1.590000e+02
376082 5.224089e+01 1.492613e+01 1.590000e+02
376083 5.708924e+01 1.495117e+01 1.590000e+02
376084 5.548522e+01 9.759400e+00 1.590000e+02
376085 8.385050e+00 5.195167e+00 1.590000e+02
376086 1.899878e+01 4.976514e+00 1.590000e+02
376087 3.005530e+01 4.995937e+00 1.590000e+02
376088 4.130539e+01 4.987408e+00 1.590000e+02
376089 5.299195e+01 4.918079e+00 1.590000e+02
376090 3.565900e+01 4.998748e+00 1.590000e+02
376091 1.361864e+01 4.980837e+00 1.590000e+02
376092 2.449252e+01 4.987482e+00 1.590000e+02
376093 4.701812e+01 4.962923e+00 1.590000e+02
376094 1.146732e+01 9.982482e+00 1.590000e+02
376095 4.977561e+01 9.895677e+00 1.590000e+02
376096 7.028907e+00 9.986313e+00 1.590000e+02
376097 3.286573e+01 1.000079e+01 1.590000e+02
376098 1.648451e+01 9.990929e+00 1.590000e+02
376099 2.181702e+01 9.995931e+00 1.590000e+02
376100 2.730234e+01 9.999601e+00 1.590000e+02
376101 4.411424e+01 9.961647e+00 1.590000e+02
376102 3.847344e+01 9.991983e+00 1.590000e+02
cgnodes_mode: total nodes 61
Center of gravity 2.971871e+01 1.006882e+01 1.590000e+02
all.fbd opened
 write fbd
 ready
/tmp/cgxcmd opened
 reading file
 636907 nodes reallocated
 2279212 elements reallocated
 ready
WRITEINONE command:
path = `'
exec SEND ALL ABQ
 write abaqus data
 file all.msh opened
 ready
 ready
 ready
 write file: FissoF4.nam
 ready
 write file: FissoF3.nam
 ready
 write file: FissoF2.nam
 ready
 write file: FissoF1.nam
 ready
 write file: ForzanteF4.nam
 ready
 write file: ForzanteF3.nam
 ready
 write file: ForzanteF2.nam
 ready
 write file: ForzanteF1.nam
 ready
 write file: C3D4.nam
 ready
 write file: Fisso.nam
 ready
 write file: Forzante.nam
 ready
 write file: all.nam
 ready
 ready
 write file: all.sur
 ready
 ready
current dir = /tmp
copy all.msh ->
copy Forzante.nam ->
execute  Forzante abq sur
 write file: Forzante.sur
 ready
 ready
copy Fisso.nam ->
execute  Fisso abq sur
 write file: Fisso.sur
 ready
 ready
copy C3D4.nam ->
execute  C3D4 abq sur
 write file: C3D4.sur
 ready
 ready
copy ForzanteF1.nam ->
execute  ForzanteF1 abq sur
 write file: ForzanteF1.sur
 ready
 ready
copy ForzanteF2.nam ->
execute  ForzanteF2 abq sur
 write file: ForzanteF2.sur
 ready
 ready
copy ForzanteF3.nam ->
execute  ForzanteF3 abq sur
 write file: ForzanteF3.sur
 ready
 ready
copy ForzanteF4.nam ->
execute  ForzanteF4 abq sur
 write file: ForzanteF4.sur
 ready
 ready
copy FissoF1.nam ->
execute  FissoF1 abq sur
 write file: FissoF1.sur
 ready
 ready
copy FissoF2.nam ->
execute  FissoF2 abq sur
 write file: FissoF2.sur
 ready
 ready
copy FissoF3.nam ->
execute  FissoF3 abq sur
 write file: FissoF3.sur
 ready
 ready
copy FissoF4.nam ->
execute  FissoF4 abq sur
 write file: FissoF4.sur
 ready
 ready
copy FissoF4.sur ->
copy FissoF3.sur ->
copy FissoF2.sur ->
copy FissoF1.sur ->
copy ForzanteF4.sur ->
copy ForzanteF3.sur ->
copy ForzanteF2.sur ->
copy ForzanteF1.sur ->
copy C3D4.sur ->
copy Fisso.sur ->
copy Forzante.sur ->
copy all.sur ->
 ready
AREA:58576.038604  CENTER OF GRAVITY: 30.065419 10.091373 24.470163
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
pre_area2() f=0 !
cgnodes mode
 write abaqus data
 ready
AREA:1240.000000  CENTER OF GRAVITY: 30.000000 10.000000 -105.000000
AREA:1240.000000  CENTER OF GRAVITY: 30.000000 10.000000 159.000000
all.fbd opened
 write fbd
 ready
ElMastro
Re: mesh region
Postby ElMastro » Tue Jul 02, 2019 10:29 am
I'm reading now the last post. It doesn't work.
I can't open the *.unv files from Salome, Freecad freezes and keeps loading for what seems forever...
bernd
Re: mesh region
Postby bernd » Tue Jul 02, 2019 10:36 am
would you post the unv?
ElMastro
Re: mesh region
Postby ElMastro » Tue Jul 02, 2019 10:52 am
Well, it finished loading.
I can confirm that importing the *.unv in freecad and exporting form it, everything works in calculix launcher, however in freecad the groups aren't listed.
