mesh region
ElMastro
Re: mesh region
Postby ElMastro » Tue Jul 02, 2019 10:57 am
Mesh.unv.zip
(83.15 KiB) Downloaded 2 times
This one is the one made with freecad. I can't post the meshes made with Salome because they are 384 Mb each one. I'll make some smaller ones and post them.
bernd
Re: mesh region
Postby bernd » Tue Jul 02, 2019 6:32 pm
ElMastro wrote:
Tue Jul 02, 2019 10:52 am
Well, it finished loading.
I can confirm that importing the *.unv in freecad and exporting form it, everything works in calculix launcher, however in freecad the groups aren't listed.
great than we will be able to make one with FreeCAD too :)
bernd
Re: mesh region
Postby bernd » Tue Jul 02, 2019 6:33 pm
... I'll make some smaller ones and post them.
cool
ElMastro
Re: mesh region
Postby ElMastro » Wed Jul 03, 2019 3:14 pm
Brnd, here are the files:
Mesh_from_Salome.unv.zip
Mesh created with Salome Meca
(17.82 KiB) Downloaded 4 times
Saved_with_freecad.unv.zip
Same mesh, imported and exported with Freecad
(17.82 KiB) Downloaded 3 times
The first made with Salome, the later imported and exported with freecad.
I have to make a correction I noted that in Data/Property tab there are listed 4 groups after import (I believe two should probably be the nodesets)
bernd
Re: mesh region
Postby bernd » Wed Jul 03, 2019 3:23 pm
If a mesh is imported, no FreeCAD FEM mesh group objects (which will generate mesh groups on meshing) are created, but the mesh group data of the unv will be imported and is visible as you mentioned in the Data/Property tab. By python you have full access to all this data.
But more interesting to me is:
Mesh_from_Salome.unv.zipSaved_with_freecad.unv.zip The first made with Salome, the later imported and exported with freecad.
Does this unv exported from FreeCAD works together with CalculiX luncher?
ElMastro
Re: mesh region
Postby ElMastro » Wed Jul 03, 2019 4:29 pm
Yes the one exported from freecad works. It shows two groups and a certain quantity of submesh/nodeset. The two groups do have different names but occupy the same face. Probably I did wrong something on Salome Meca
bernd
Re: mesh region
Postby bernd » Thu Jul 04, 2019 10:31 am
import the unv exported with Salome and play with Python in FreeCAD ...
mesh = App.ActiveDocument.Mesh_from_Salome.FemMesh
for g in mesh.Groups:
    mesh.getGroupName(g)
    mesh.getGroupElementType(g)
    mesh.getGroupElements(g)
# for some reason the groups are saved twice ... means we are only interested in Face group with ID 0 and Node group ID 2
# I assume the nodes are the nodes of the faces group ... We will gone check this ...
# get all nodes for the faces group
grfaces = mesh.getGroupElements(0)
grnodes = mesh.getGroupElements(2)
nodes_of_grfaces = []
for f in grfaces:
    nodes_of_grfaces += list(mesh.getElementNodes(f))
nodes_of_grfaces = tuple(sorted(list(set(nodes_of_grfaces))))
if nodes_of_grfaces == grnodes:
    print('The Node group ID 2 are the nodes of the Faces from Face group with ID 0')
# YEAH ... :-) q.e.d
# Lets make a mesh out of it to see what Faces are in Face group with ID 0
import Fem
grmesh = Fem.FemMesh()
for n in grnodes:
    nvec = mesh.getNodeById(n)
    grmesh.addNode(nvec.x, nvec.y, nvec.z, n)
for f in grfaces:
    grmesh.addFace(list(mesh.getElementNodes(f)), f)
Fem.show(grmesh)
Salome_mesh_get_the_groups.FCStd
(26.23 KiB) Downloaded 3 times
bernd
Re: mesh region
Postby bernd » Thu Jul 04, 2019 10:40 am
since we have all informations, lets make the mesh with FreeCAD, print some informations and export it to unv ...
Salome_mesh_made_with_FreeCAD.FCStd
(44.07 KiB) Downloaded 7 times
Mesh_from_Salome.unv.txt
(163.92 KiB) Downloaded 7 times
informations:
mesh = App.ActiveDocument.FEMMeshGmsh.FemMesh
...     mesh.getGroupName(g)
...     mesh.getGroupElementType(g)
...     mesh.getGroupElements(g)
'FEMMeshGroup'
'Face'
(593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696)
Would you be so kind and test this unv in CalculiX luncher ?
ElMastro
Re: mesh region
Postby ElMastro » Fri Jul 05, 2019 11:14 am
Sorry, I can't
when running
'FEMMeshGroup'
'Face'
it says
File "<input>", line 5
SyntaxError: invalid syntax
However when I input Mesh_from_Salome.unv.txt in Calculix launcher it shows two groups
bernd
Re: mesh region
Postby bernd » Fri Jul 05, 2019 4:13 pm
you get an syntax error on
