extraction of negative eigenvalues
UR_
Re: extraction of negative eigenvalues
Postby UR_ » Mon Jul 01, 2019 11:55 am
bernd wrote:
Mon Jul 01, 2019 11:05 am
the reader code never changed over the years
phpBB [video]
PrzemoF
Postby PrzemoF » Mon Jul 01, 2019 12:07 pm
UR_ wrote:
Mon Jul 01, 2019 9:16 am
Just tried a frequency analysis by modifying cantilever3D example from start page.
Got mode 1 to 15.
If I select result object e.g. "CalculiX_frequency_mode_1_results", I see in properties:
But same values for all modes :?
Where is the beaf? :confused:
Check if you see the results in the file produced by CalculiX. If it's there then the reader is broken, but I doubt it - it worked since it was added to the FreeCAD code. Another option is change of formatting by CalculiX, but that's unlikely. Post the model, so someone can check it.
P.S. I never dreamt that the reader code might survive that long without modifications :D
UR_
Postby UR_ » Mon Jul 01, 2019 12:17 pm
FemCalculixCantilever3D.FCStd
(620.53 KiB) Downloaded 15 times
Box_Mesh.dat.zip
(2.13 KiB) Downloaded 17 times
bernd
Postby bernd » Mon Jul 01, 2019 12:51 pm
I can confirm the problem for 0.19 Just open FEM 3D example change from static to frequancy analysis.
Ahh it works in 0.18.2 ... :) which means I may am the culprit in one of the lots of code refactoring commits ... I will have a look ...
bernd
Postby bernd » Mon Jul 01, 2019 4:04 pm
my vault ... :oops:
I deleted this line https://github.com/FreeCAD/FreeCAD/blob ... em.py#L284 I will have a look how to fix this.
bernd
Postby bernd » Mon Jul 01, 2019 7:45 pm
git commit 20b78fc fixes the eigenmode reading. Back to the origin question ...
Is the eigenmode we gone read from dat file the right one ??? https://github.com/FreeCAD/FreeCAD/blob ... py#L94-L95
HarryvL
Postby HarryvL » Mon Jul 01, 2019 11:56 pm
Judging from the table in the first post the entries in the frequency line are as follows:
<mode number> <real part of frequency in rad/s> <real part of frequency in Hz> <imaginary part of frequency in rad/s> <imaginary part of frequency in Hz>
EDIT: this is not correct. see: https://forum.freecadweb.org/viewtopic. ... 30#p319635
HarryvL
Postby HarryvL » Tue Jul 02, 2019 12:08 am
A practical example of a natural frequency analysis where the imaginary part of the response needs to be considered:
https://forum.freecadweb.org/viewtopic. ... 50#p232717
EDIT: this relates to imaginary response modes and not to imaginary frequencies
bernd
Postby bernd » Sat Jul 06, 2019 10:50 am
- start FreeCAD
- load FEM 3D example
- change to analysis type frequency
- change from first 15 to first 8 frequencies
- delete constraint fixed and constraint force
- run analyisis
- the imaginary part in Hz is missing
- screen and file attached
test.FCStd
(330.26 KiB) Downloaded 14 times
Box_Mesh.dat.txt
(3.07 KiB) Downloaded 12 times
bernd
Postby bernd » Sat Jul 06, 2019 11:03 am
but I can the rad/Time use as well ... https://en.wikipedia.org/wiki/Radian_per_second just use /2pi ...
