shell elements share the same node ?
atakebones
Postby atakebones » Thu Jul 11, 2019 12:37 pm
Calculation stops with such an error message
What cause can be considered
*INFO in gen3dnor: in some nodes opposite normals are defined
*ERROR in gen3dnor: more than 100 ?hell elements share the
same node
2.2: CalculiX execute error:
このようなエラーメッセージで計算が止まります
どんな原因が考えられるでしょうか
Re: shell elements share the same node ?
Postby bernd » Thu Jul 11, 2019 12:51 pm
seams some bad mesh. Difficault to say what caused the mesh to be bad. Would you post the FreeCAD file with mesh cleared?
Postby bernd » Thu Jul 11, 2019 12:52 pm
Make sure to use 0.19 dev version if you gone work with FEM. See https://forum.freecadweb.org/viewtopic.php?f=18&t=12212
