[Solved] Requested property: [Material], not found
Erni24
Postby Erni24 » Sat Jul 13, 2019 9:54 am
Hi all,
I try to follow anisim's video "How to use two materials". But run into a problem with electrostatic simulation.
I can create the mesh, i assign air and steel to solid1 and solid2 of the compSolid.
The sif file is written, starting the simulation runs for a while...
Then in the solver window:
SingleSolver: Attempting to call solver
SingleSolver: Solver Equation string is: stat elec solver
StatElecSolve: -------------------------------------
StatElecSolve: STATELEC SOLVER:
DefaultStart: Starting solver: stat elec solver
StatElecSolve: Starting Assembly...
WARNING:: ListFind:
WARNING:: ListFind:  Requested property: [Material], not found
WARNING:: ListFind:
and in the output panel:
Exception (Sat Jul 13 11:45:01 2019): File to load not existing or not readable: case0001.vtu
Exception in thread Thread-60:
  File "/tmp/.mount_FreeCAe6p9QU/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner
    self.run()
  File "/tmp/.mount_FreeCAe6p9QU/usr/lib/python3.7/threading.py", line 865, in run
    self._target(*self._args, **self._kwargs)
  File "/tmp/.mount_FreeCAe6p9QU/usr/Mod/Fem/femsolver/task.py", line 115, in protector
    self.run()
  File "/tmp/.mount_FreeCAe6p9QU/usr/Mod/Fem/femsolver/elmer/tasks.py", line 137, in run
    self.solver.ElmerResult.read(postPath)
Base.FreeCADError: {'sclassname': 'N4Base13FileExceptionE', 'sErrMsg': 'File to load not existing or not readable', 'sfile': '', 'iline': 0, 'sfunction': '', 'swhat': 'File to load not existing or not readable: case0001.vtu', 'btranslatable': False, 'breported': True, 'filename': 'case0001.vtu'}
How can i fix this?
Dietmar
OS: Debian GNU/Linux bullseye/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.17349 (Git) AppImage
Hash: 7eccda34d090ab641b29fa4be24c515cfa39c601
Python version: 3.7.3
Qt version: 5.9.7
Re: Requested property: [Material], not found
Postby chrisb » Sat Jul 13, 2019 10:29 am
Hi Dietmar, can you please edit your post and change the quote tags to code tags. It keeps the indentation and improves readability.
bernd
Postby bernd » Sat Jul 13, 2019 1:12 pm
you use a very old version ! FEM development is fast! Would you try on 0.18.2 or even better on latest 0.19.x
Erni24
Postby Erni24 » Sat Jul 13, 2019 2:40 pm
Hope you just red the version in a wrong way. I downloaded the AppImage yesterday from dev tree :D
Postby Kunda1 » Sat Jul 13, 2019 3:11 pm
Yea, it's the dev version, @bernd
Erni24
Postby Erni24 » Sat Jul 13, 2019 5:09 pm
I figured out one point.
1) in the sif file is no material section
Erni24
Postby Erni24 » Sun Jul 14, 2019 3:09 pm
adding a material section allows me to start the simulation, but it ends in an error:
Solver binary path: /usr/local/bin/ElmerSolver
Exception (Sun Jul 14 16:58:03 2019): File to load not existing or not readable: case0001.vtu
Exception in thread Thread-74:
  File "/tmp/.mount_FreeCAmnGlcv/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner
    self.run()
  File "/tmp/.mount_FreeCAmnGlcv/usr/lib/python3.7/threading.py", line 865, in run
  File "/tmp/.mount_FreeCAmnGlcv/usr/Mod/Fem/femsolver/task.py", line 115, in protector
    self.run()
  File "/tmp/.mount_FreeCAmnGlcv/usr/Mod/Fem/femsolver/elmer/tasks.py", line 137, in run
the section in the sif file looks like:
Body 1
  Equation = Integer 1
  Name = String "Solid1"
  Material = Integer 1
End
Material 1
  Relative Permittivity = Real 1.0
End
Erni24
Postby Erni24 » Sun Jul 14, 2019 4:03 pm
next step...
if i put
Relative Permittivity = 1.00058986
into (for instance) Air.FCMat file, the material section in case.sif is written. Seems to be, the material files for dielectric materials need an improvement.
bernd
Postby bernd » Mon Jul 15, 2019 4:23 am
:oops: my misstake
bernd
Postby bernd » Mon Jul 15, 2019 4:25 am
next step...
if i put
this shoul be catched in elmer writer somehow.
About the mat files ... Would you edit all fluid materials in this regard?
