[Solved] Requested property: [Material], not found
Erni24
Re: Requested property: [Material], not found
Post by Erni24 »
Sure.
I would be happy to contribute. This as first step. Second I ask you for an edit account for the user wiki. It would be good to write down my experiences in the wiki under Elmer electrostatic
But how can I edit the files? I can edit them locally and send it all to you. There are not so many files...
Erni24 wrote: Mon Jul 15, 2019 6:09 am Second I ask you for an edit account for the user wiki.
How to get wiki editing permissions
Always glad to see more helping hands.
Post by bernd »
Erni24 wrote: Mon Jul 15, 2019 6:09 am Sure.
edit them and post them as zip here on the forum is fine, but you could become a official FreeCAD developer if you use github for this. Since the changes are quite small you could do anything in github web system directly on the internet
- Use your github account if you have one (or make one if you do not have one)
- all the following could be done directly on github in the internet
- forge FreeCAD
- create a new branch
- edit the files, commit the changes
- make a PullRequest to this branch: https://github.com/berndhahnebach/FreeC ... ree/femdev
Post by bernd »
Erni24 wrote: Mon Jul 15, 2019 6:09 am It would be good to write down my experiences in the wiki under Elmer electrostatic
A small tutorial how to perform a electrostatic analysis with elmer and FreeCAD FEM on a small example would be great!
I do not know anything about electrostatic analysis. Is it possible to take an example which could be calculated by pen, paper and a calculator to compare the results. Including this would be cool. Like FEM_CalculiX_Cantilever_3D (actually the calculation of the 88.4 mm by pen and paper is missing, but it is just one formula)
Erni24
Post by Erni24 »
Ouch, 15 years after leaving university...
Sure with pencil and paper? :D
But yes, point load against grounded plate should be possible.
Erni24
Post by Erni24 »
first two materials updated. Hope the pull request is ok.
Dietmar
sgrogan
Re: [Solved] Requested property: [Material], not found
Post by sgrogan »
Erni24 wrote: Tue Jul 16, 2019 6:16 pm Sure with pencil and paper? :D
You guys have my attention now :geek:
How about a simple coaxial transmission line?
Also see here for info on EM WB (it doesn't use elmer) https://github.com/ediloren/EM-Workbench-for-FreeCAD
"fight the good fight"
