How to use main axes or datums as direction for applied forces
uwestoehr
Postby uwestoehr » Thu Jul 18, 2019 12:28 pm
When setting the direction of a force I am not able to tell FC that it should use one if the main axes or a datum line. I assume I only use a wring setting.
Here is an example:
screenshot
The force should act along the datum line. How do I achieve this? In the constraint dialog the datum line is not recognized.
Jee-Bee
Re: How to use main axes or datums as direction for applied forces
Postby Jee-Bee » Thu Jul 18, 2019 1:49 pm
I asked this before see https://forum.freecadweb.org/viewtopic. ... hilit=axis
At that time there was not enough interest or need to fix it. New request new possebilities...
bernd
Postby bernd » Thu Jul 18, 2019 7:10 pm
best to make a feature request on mantis and link to the two topics. Force contraint gui was done in C++. Means this is not done just in 10 minutes for me. Therefor chances are very small that I will try to add this. But if it is on mantis may be some other is more interested and will give it a try.
bernd
bernd
Postby bernd » Thu Jul 18, 2019 7:12 pm
is it just not recognised by the force gui or does the property nit wor with this planes at all. Try to set it with property editor!
Jee-Bee
Postby Jee-Bee » Thu Jul 18, 2019 7:58 pm
Not recognized by gui
i added a easy example you can try
Fem_planes.FCStd
(13.53 KiB) Downloaded 16 times
uwestoehr
Postby uwestoehr » Thu Jul 18, 2019 10:30 pm
Yes. I can e.g. as workaround draw a line along a main axis or datum line to get the direction I need but it would speed it up a lot if the FEM dialogs would recognize these elements as source for a direction.
I opened now issue #4064.
Jee-Bee
Postby Jee-Bee » Fri Jul 19, 2019 5:03 am
The request you created is mainly about the direction parallel to the selected axis(that's what i read at least).
Would it be possible to extend the request to add planes too? But when selecting a plane the the force direction is normal to/ perpendicular to the plane...
Postby chrisb » Fri Jul 19, 2019 10:22 am
+1
uwestoehr
Postby uwestoehr » Fri Jul 19, 2019 11:06 am
This is a very useful proposal I fully support!
However, from the technical point of view this has to be implemented differently I guess (an axis(line has a direction that is immediately accessible while the normal of a plane has to be calculated). Therefore I propose that you open another feature request (where you can refer to the one I created if you like).
Postby chrisb » Fri Jul 19, 2019 11:39 am
ping
Do you prefer one or two tickets?
