[SOLVED] FEM output does not seem to be correct (beginner question)
ceremcem
Postby ceremcem » Tue Jul 30, 2019 7:06 pm
I started learning FEM by this video. However, my model doesn't seem to be analyzed correctly:
I would expect the upper "bar" has some stress (some red areas), just like in "Abs displacement" mode:
However, in "Abs displacement" mode I can see no stress on the "lower bar".
I don't know what "Abs displacement" or "Tresca" means (I'm following the French Cafe technique) but I can't obtain a result that is similar to my expectation (which is something like combination of the "Abs displacement" and "Tresca" modes).
Is it my lack of knowledge or are there some missing/wrong steps here?
fem2-test.FCStd
(588.57 KiB) Downloaded 15 times
PrzemoF
Re: FEM output does not seem to be correct (beginner question)
Postby PrzemoF » Tue Jul 30, 2019 8:50 pm
Looks good to me. Tested on my setup - visually the same results.
My tutorial - FEM in 60 seconds - https://peertube.social/videos/watch/d7 ... 91a69a1446
bernd
Postby bernd » Tue Jul 30, 2019 9:15 pm
looks got to me too ...
ickby
Postby ickby » Thu Aug 01, 2019 2:18 pm
what you see is correct. The options show what data of the result is used to color the part. "Abs displacement" means it uses the displacement vector, the absolute value of it. Hence sqrt(dx^2+dy^2+dz^2) where dx and dy is the displacement in x and y direction. So you see no color at the bottom truss as it is closer to the contraint and hence moves way less than the top truss.
So your pictire has nothing to do with the stress in the part. To see the stress you should use "Von Mises stress".
PrzemoF
Postby PrzemoF » Thu Aug 01, 2019 2:50 pm
[..]I would expect the upper "bar" has some stress (some red areas), just like in "Abs displacement" mode[..]
There is a strip of yellow at the top and bottom of the beam if you take a close look. Red is the top of the scale - try to play with a simple beam and different support and different forces - you'll get a feeling quickly what to expect and where in terms of stress and displacement.
ceremcem
Postby ceremcem » Fri Aug 02, 2019 11:41 am
If you all say so, then it's probably my misinterpretation.
Well, now I started to get the idea. Moreover I couldn't notice any difference between "Von Mises Stress" and "Max Shear Stress" by the naked eyes. However, taking two screenshots and subtracting one from the other pixel by pixel outputs the slight difference:
I'm going to stick with "Von Mises Stress" till I understand what "Tresca" means.
Is there a way to customize the scale where I would like to highlight any area whose stress (or displacement) exceeds a specific limit? (Or better, I'd like to make whole model highly transparent and make the high stress areas more opaque which would provide an X-ray like vision at any angle)
I got what you suggested. Here is a screenshot that looks like just I would expected:
fandaL
Re: [SOLVED] FEM output does not seem to be correct (beginner question)
Postby fandaL » Sat Aug 03, 2019 11:55 am
... Moreover I couldn't notice any difference between "Von Mises Stress" and "Max Shear Stress" by the naked eyes...
"Von Mises Stress" and "Max Shear Stress" are two approaches to answer same question: how to get equivalent stress (one simple number instead of normal and shear stresses in all directions). So they give similar value.
Try to play with Pipeline postprocessing, e.g. with “Scalar Clip Filter”. Some hints according to this are on the end of this tutorial https://www.freecadweb.org/wiki/FEM_She ... site_Block
PrzemoF
Postby PrzemoF » Mon Aug 05, 2019 1:30 pm
[..]Well, now I started to get the idea. Moreover I couldn't notice any difference between "Von Mises Stress" and "Max Shear Stress" by the naked eyes.[..]
Image from wikipedia
https://en.wikipedia.org/wiki/Von_Mises_yield_criterion
ceremcem
Postby ceremcem » Sat Aug 10, 2019 12:09 am
I appreciate all of you for your helps and tips. I could barely understand the difference between Von Mises Stress and Tresca. I suppose choosing either one won't make much difference for me at this stage.
I finally managed to follow the tutorial. Here is my result. Thanks!
