FEM analysis requires some steps that require huge computation times (minutes to hours depending the complexity and the size of the model), such as generating the mesh, creating the .inp file and running CalculiX.
Is there a way to distribute those operations across computers?
How to distribute CPU intensive operations?
Re: How to distribute CPU intensive operations?
In general, first, I would recommend to use appropriate approach: if possible use model symmetry, appropriate element type (1d, 2d, 3d) and mesh size or even use hand calculations instead of FEA, ... All this should correspond with output (precision) you require.
Edit → Preferences → FEM → CalculiX → Solver defaults → Number of CPU's to use
When using GMSH, you can also use local mesh refinement where you are interested in higher precision by "FEM mesh region"
I’m not aware of distributing a task between more computers (except that you can generate inp file on PC and run analysis on stronger computer/cloud), but CalculiX is able to use more CPU threads. Look at
I'm not aware of any math operations or processes taking place under the hood of FEA (I'm electronics engineer). However I understand that I should learn it immediately if this is a must.fandaL wrote: ↑Sun Aug 11, 2019 9:11 am In general, first, I would recommend to use appropriate approach: if possible use model symmetry, appropriate element type (1d, 2d, 3d) and mesh size or even use hand calculations instead of FEA, ... All this should correspond with output (precision) you require.
AFAIK, a code (calculation work of an algorithm) can only be distributed among the CPU threads or cores if it is designed specially to be able to map (partition the calculations) and reduce (merge the results). If CalculiX can use multiple threads/cores then theoretically it should be able to map and reduce its operations. If we could briefly know the internals, then we could split the data accordingly, send to several computers (eg. over SSH), compute the sub-results, then fetch them and merge to achieve the actual result.
Assembly 3 notes: https://github.com/ceremcem/freecad-notes
It depends on the solver implementations, but some support it over MP, e.g. elmer and fenics. Especially elmer should work in freecad pretty well. So you should carefully choose the right solver and than try to use their capabilities.
