FreeCAD CalculiX Fails to write .frd file
chopboy
Postby chopboy » Thu Aug 15, 2019 4:18 am
I've been using FreeCAD for a little while to model geometry for Salome - Openfoam, and recently attempted to utilise the FreeCAD FEM workbench for FEA linear stress analysis. Using the tutorials I have been able to build a case, write an input file and run the case. However the solver gets to the'
271.6: CalculiX done without error!
271.6: Loading result sets...
'stage and stops. There is a .frd file created at 7kb in size only.
The input file appears valid as I can run calculiX on the file externally to FreeCAD and it completes + writes an .frd file (20+Mb).
I'm on CAElinux (ubuntu) using FreeCAD 18 Build: 16131.
Has anyone experienced this or could point me in the direction to look for a solution?
I have not at this stage confirmed results from the external CalculiX run as I do not have a .frd post-processor aside from FreeCAD,
A follow up question: is it possible to load a .frd file created externally into FreeCAD for post processing?
The Following is the error log from FreeCAD 19:
PySide2.QtCore.QProcess.ProcessState.Running
Error() PySide2.QtCore.QProcess.ProcessError.Crashed
calculixFinished() 11
PySide2.QtCore.QProcess.ProcessState.NotRunning
PySide2.QtCore.QRegExp('\*ERROR.*\n\n', 1, 0)
We will load the ccx frd and dat result file.
Read ccx results from frd file: /tmp/femuhooy5mc/FEMMeshNetgen.frd
FEM: No nodes found in Frd file.
Problem on frd file import. No nodes found in frd file.
File "/tmp/.mount_FreeCANBCX2n/usr/Mod/Fem/femguiobjects/_ViewProviderFemSolverCalculix.py", line 308, in calculixFinished
self.fea.load_results()
File "/tmp/.mount_FreeCANBCX2n/usr/Mod/Fem/femtools/ccxtools.py", line 1110, in load_results
self.load_results_ccxfrd()
File "/tmp/.mount_FreeCANBCX2n/usr/Mod/Fem/femtools/ccxtools.py", line 1119, in load_results_ccxfrd
importCcxFrdResults.importFrd(frd_result_file, self.analysis, 'CCX_')
File "/tmp/.mount_FreeCANBCX2n/usr/Mod/Fem/feminout/importCcxFrdResults.py", line 192, in importFrd
return res_obj
UnboundLocalError: local variable 'res_obj' referenced before assignment
OS: Ubuntu 16.04.6 LTS (XFCE/xubuntu)
Version: 0.19.17646 (Git) AppImage
Hash: 641d946fa47573562026e042b1706759bd47611e
Python version: 3.7.3
Qt version: 5.12.1
(edit to add error log and installation details)
fandaL
Re: FreeCAD CalculiX Fails to write .frd file
Postby fandaL » Thu Aug 15, 2019 11:52 am
Yes, it should work in the same way as if it is loaded automatically. Just drag and drop .frd file.
Error message looks similar to this thread https://forum.freecadweb.org/viewtopic.php?f=18&t=38450
chopboy
Postby chopboy » Thu Aug 15, 2019 10:20 pm
An Update on my progress to date:
I've tested again on a different virtual machine and the FreeCAD analysis completed successfully. It may be that my current VM is not working properly or is damaged in some way. I know Salome-CFD will no longer run on the machine, so there may be some dependency missing.
bernd
Postby bernd » Fri Aug 16, 2019 3:13 am
From the above it seams the frd file is not valid becaus there where some problem during calculix run. As stated just drag and drop the frd file, or use file open to open it and see if it realy has problems.
You could also try to run the calculix input file created from FreeCAD directly in a shell by "ccx -i filename_without_.inp" and again load the frd file manually. With this it should be possible to tackle it down.
bernd
bernd
Postby bernd » Fri Aug 16, 2019 3:15 am
These are different ones ... For FEM I stongly recomend 0.19 versions !
