Error: "double free or corruption (fasttop)" at Gmsh calculation on simple long tube
zoe
Postby zoe » Mon Aug 19, 2019 5:05 pm
Hello this is the system:
OS: Ubuntu 18.04.3 LTS
Version: 0.18.3.
Python version: 3.6.8
Qt version: 5.9.5
I surrounded my problem but I dont understand it.
I made a tube from a sketch with two circles radius 53,55mm and 57,15mm. Then a Pad with length 744,98mm.
I switch Workspace to FEM mark the tube and click the Gmsh Icon and execute Gmesh.
Now I dont see a finished mesh and get the following output:
  • 0.0: We are going to start ...
    0.0: Start Gmsh ...
    0.5: Gmsh had warnings ...
    0.5: double free or corruption (fasttop)
    0.5: Gmsh done!
I cancel Gmsh and change the length of the Pad to 300mm and repeat Gmsh execution.
Now I see a generated mesh and get an other output:
    0.0: Start Gmsh ...
    0.4: Gmsh had warnings ...
    0.4: [35mWarning : Surface mesh: worst distortion = -1.26646 (avg = 0.944898, 16 elements with jac.
    0.4: Gmsh done!
So my problem is, that the size of the tube makes 2 different warnings but I dont find deeper Information whats wrong.
It would be greate if you can help me to find a solution.
bernd
Re: Error: "double free or corruption (fasttop)" at Gmsh calculation on simple long tube
Postby bernd » Tue Aug 20, 2019 4:57 am
Would you post the geometry you have problems with and would you post the version number of gmsh?
zoe
Postby zoe » Tue Aug 20, 2019 8:09 am
I just repoduced the problem to make a screenshot. With the beginning length of 744,98mm the Gmsh execution took 0 seconds without error or warning and produced a Mesh with 0 Nodes, 0 Edges ... an empty Mesh i guess.
After that I changed the length to 300 and it behaves like in the previous description.
Here is a screenshot:
Here is the About page from Gmsh:
version 3.0.6
* Build date: 20171107
* Build host: lgw01-amd64-034
* Build options: 64Bit Ann Bamg Bfgs Blas(Generic) Blossom C++11 Cgns Chaco DIntegration Dlopen Fltk Gmm Jpeg Kbipack Lapack(Generic) LinuxJoystick MPI MathEx Med Mesh Mmg3d Mpeg NativeFileChooser Netgen ONELAB ONELABMetamodel OpenCASCADE OpenGL OptHom Parser Plugins Png Post Python Solver TetGen/BR Tetgen Voro3D Zlib
* FLTK version: 1.3.4
* OCC version: 6.9.1
* MED version: 3.0.6
* Packaged by: buildd
UR_
Postby UR_ » Tue Aug 20, 2019 3:25 pm
Same error message with Gmsh 4.4.1
Accordingly to rule "garbage in, garbage out!" this inputs gives much better results
Screenshot 001.png (20.27 KiB) Viewed 289 times
Screenshot 002.png (124.2 KiB) Viewed 289 times
We are going to start Gmsh FEM mesh run!
  Part to mesh: Name --> Cut,  Label --> Cut, ShapeType --> Compound
  CharacteristicLengthMax: 5.0
  CharacteristicLengthMin: 0.0
  ElementOrder: 2
  ElementDimension: 3
  C:\Users\aio\AppData\Local\Temp\Cut_Geometry.brep
  C:\Users\aio\AppData\Local\Temp\Cut_Mesh_TmpGmsh.unv
  C:\Users\aio\AppData\Local\Temp\shape2mesh.geo
  C:/Program Files/FEMbinpack/bin/gmsh_4.4.1.exe
  No Group meshing for analysis.
Start: ViewProviderFEMMeshBuilder::createMesh() =================================
    0.010000: Start build up 290312 face helper
    0.105000: Start eliminate internal faces GRID
      Size:F:5.000000,  X:5  ,Y:5  ,Z:31
      VoxelSize: Max:756 ,Average:374
    0.231000: Start build up node map
    0.289000: Start set point vector
    0.299000: Start count triangle size
    NumTriangles:189256
    0.301000: Start build up triangle vector
    0.601000: Start build up edge vector
    NumEdges:283884
    0.627000: Finish =========================================================
  The Part should have a pretty new FEM mesh!
Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid
========================== Dump contents of mesh ==========================
1) Total number of nodes:      	143549
2) Total number of edges:      	578
3) Total number of faces:      	47314
4) Total number of polygons:   	0
5) Total number of volumes:    	72578
6) Total number of polyhedrons:	0
7) Total number of linear edges:	0
8) Total number of linear faces:	0
9) Total number of linear volumes:	0
10) Total number of quadratic edges:	578
11) Total number of quadratic faces:	47314
11.1) Number of quadratic triangles:  	47314
11.2) Number of quadratic quadrangles:	0
12) Total number of quadratic volumes:	72578
12.1) Number of quadratic hexahedrons: 	0
12.2) Number of quadratic tetrahedrons:	72578
12.3) Number of quadratic prisms:      	0
12.4) Number of quadratic pyramids:    	0
TubeMesh.FCStd
(10.38 KiB) Downloaded 10 times
So please have a look at yours tetrahedrons aspect ratio, especially if you are using thin walled tubes. ;)
