Error while setting material
usbhub
Postby usbhub » Sat Aug 24, 2019 7:40 pm
Hello
I hope this is not a duplicate, but I can't find any similar bug.
If you click on "Creates a FEM material for solid" then you get this error in the output window, but you get a material, but if you try to start the calculation, you get an error message ("No YoungsModulus defined for at least one material.
No PoissonRatio defined for at least one material."):
  File "/usr/share/freecad/Mod/Fem/femguiobjects/_ViewProviderFemMaterial.py", line 71, in setEdit
    taskd = _TaskPanelFemMaterial(self.Object)
  File "/usr/share/freecad/Mod/Fem/femguiobjects/_ViewProviderFemMaterial.py", line 151, in __init__
    self.import_materials()
  File "/usr/share/freecad/Mod/Fem/femguiobjects/_ViewProviderFemMaterial.py", line 574, in import_materials
    self.import_solid_materials()
  File "/usr/share/freecad/Mod/Fem/femguiobjects/_ViewProviderFemMaterial.py", line 581, in import_solid_materials
    self.add_cards_from_a_dir(system_mat_dir, ":/icons/freecad.svg")
  File "/usr/share/freecad/Mod/Fem/femguiobjects/_ViewProviderFemMaterial.py", line 620, in add_cards_from_a_dir
    self.materials[a_path] = Material.importFCMat(a_path)
  File "/usr/share/freecad/Mod/Material/Material.py", line 65, in importFCMat
    Config.read(fileName, encoding='utf-8') # respect unicode filenames
<type 'exceptions.TypeError'>: read() got an unexpected keyword argument 'encoding'
I wanted to try the example with the cube and one force on it. I have used the FEM workbench already, but with another version. I wanted to try out the new functions, e.g. the beam on the right side. In the annex you find the fcstd file.
usbhub
PS: OS: Linux Mint 19
Version: 0.18.3.
Python version: 2.7.15+
Qt version: 5.9.5
bug.FCStd
(19.18 KiB) Downloaded 10 times
UR_
Re: Error while setting material
Postby UR_ » Sun Aug 25, 2019 5:35 am
Just can't say anything about version 0.18.3, because I'm using 0.19
version:
OS: Windows 10 (10.0)
Version: 0.19.17876 (Git)
Hash: c4e34ed9bea1eec2376be1520b427c84cbd7595a
Python version: 3.7.3
Qt version: 5.9.7
But can't reproduce here.
Ensure settings by Edit->Preferences->FEM->Material
Screenshot 002.png (35.96 KiB) Viewed 306 times
select a material from drop down menu (of course with appropriate Young's and Poisson values)
Screenshot 003.png (45.47 KiB) Viewed 306 times
nice results
Screenshot 004.png (20.44 KiB) Viewed 306 times
Syres
Postby Syres » Sun Aug 25, 2019 8:09 am
This is generated because the script hasn't got a Python version check therefore to make it compatible with both I would suggest changing src\Mod\Material\Material.py around line 64 from:
    Config.optionxform = str
    dict1 = {}
to:
    import sys
    if sys.version_info.major >= 3:
    else:
        Config.read(fileName)
    dict1 = {}
This will mean if you upgrade your Python (recommended) in the future it will still work.
usbhub
Postby usbhub » Sun Aug 25, 2019 7:42 pm
version:
Qt version: 5.9.7
nice results
I have not all settings that you have, maybe because the different versions.
With me the dialogue does not open, so I cant choose a material. But I will try it with the 0.19 version.
bernd
Postby bernd » Mon Aug 26, 2019 6:35 am
was fixed in early 0.19 development git commit 6a8f6e2
git commit 1e9f9fa backports this to 0.18
