Mesh groups efficiency measurements
ettaka
Postby ettaka » Mon Sep 02, 2019 8:44 pm
we are using FreeCAD with a library https://github.com/ElmerCSC/elmerfem/tr ... chFEMTools
for automated mesh creation. Our geometries can consist of many mesh groups (faces, solids). We have come to notice that FreeCAD slows down by o(n^2) when the number of mesh groups is increased.
In the image attached you can see test results using a test script (found in the FreeCADBatchFEMTools library under tests/cubemeshtest/cubemeshtest.py).
You can try this script yourself (library is tested today with daily). Write
$ python cubemeshtest.py -h
for help.
Basically the script creates a number of cubes (or spheres) in air, meshes everything and tries to find each boundary and solid (if -fb and -fs switches are used). Then it logs the time elapsed for each procedure.
I'm interested in improving this performance with some binary search or other method but I would like to get input from the community if there are someone who has worked on this.
FreeCAD cubemeshtest point search cube without air50
Re: Mesh groups efficiency measurements
Postby Kunda1 » Mon Sep 02, 2019 9:10 pm
FreeCADBatchFEMTools.py is a set of tools for handling batch type preprocessing for Elmer Solver. The library was written by Trafotek Oy in collaboration with VTT Technical Reseach Centre of Finland Ltd supported by Business Finland Oy.
Nice, the Finns have arrived :D
Welcome!
Lets ping the relevant folks
bernd wrote:
m42kus wrote:
ettaka
Postby ettaka » Mon Sep 09, 2019 11:38 am
Welcome!
Thanks!
Postby Kunda1 » Mon Sep 09, 2019 1:44 pm
I guess @bernd has been busy. He usually responds.
@m42kus is currently wrapping up his 2nd Google Summer of Code
FEM Workbench Testing: https://forum.freecadweb.org/viewtopic.php?f=18&t=35428
The first GSOC was: Elmer Integration (GSoC) - https://forum.freecadweb.org/viewtopic.php?f=18&t=22576
