workflow:
- loading "FemCalculixCantilever3D_newSolver" example from FreeCAD's start page
- ensure Edit->Preferences
- activate analysis
- open "Calculix_static_results", choose "Abs displacements" and close dialog
- open "Z88_static_results"
mouse pointer stalls:
and got this error message in report view:
Finish Editing CalculiX_static_results
TypeError: bad argument type for built-in operation
The above exception was the direct cause of the following exception:
File "C:\Users\aio\Miniconda3\envs\freecad-dev\Library\Mod\Fem\femguiobjects\_ViewProviderFemResultMechanical.py", line 328, in abs_displacement_selected
self.result_selected("Uabs", self.result_obj.DisplacementLengths, "mm")
File "C:\Users\aio\Miniconda3\envs\freecad-dev\Library\Mod\Fem\femguiobjects\_ViewProviderFemResultMechanical.py", line 455, in result_selected
self.update_colors_stats(res_values, res_unit, minm, avg, maxm)
File "C:\Users\aio\Miniconda3\envs\freecad-dev\Library\Mod\Fem\femguiobjects\_ViewProviderFemResultMechanical.py", line 462, in update_colors_stats
res_values
SystemError: <built-in method setNodeColorByScalars of FemGui.ViewProviderFemMesh object at 0x00000275A942ED98> returned a result with an error set
Start Editing Z88_static_results
tested with:
OS: Windows 10 (10.0)
Version: 0.19.18127 (Git)
Hash: a1984aeece19910c334bcd7a6622d400ddb9bd8d
Python version: 3.7.3
Qt version: 5.12.1
