FreeCAD as pre-post processor for MBDyn
Re: FreeCAD as pre-post processor for MBDyn
I have added steering and reverse to the car suspension simulation:
https://www.youtube.com/watch?v=JhQay38VGqI
Pretty happy with how this is going. I am slowly starting to put together relatively complex simulations without the need to manualy edit the input file, which shows the usability and viability of combining FreeCAD with MBDyn
You can now download this example form the Gitlab page of my project...
Holy Shmoly! That's Amazing!
I was wondering, who is keen to try to do some co-simulation with the FEM workbench?
I would like to try something like this:
https://www.youtube.com/watch?v=4KGs2BasHPA
or like this:
https://www.youtube.com/watch?v=FHPuA2VLEHk
My workbench can provide data for the magnitude and direction of the reaction forces acting on the joints for each time step of the MBD simulation. This data, along with a mesh of the part, should go into an algorithm that will perform a bunch of FEA simulations, one for each time step. The results of both, the MBD and the FEA simulations can be used to visualize the results as in the videos above...
Something like this would be a great add to FreeCAD. The hability to predict dynamic forces for FEM simulations is one of the coolest parts of a MBD simulation. So far, and as far as I know, one can only apply static forces to a FEM simulation?
In any case, would be cool to try to combine MBD and FEM for cosimulations.
or like this:
Previously I posted about a problem with rounding numbers that are obtained from the CAD and go into the input file for MBDyn. With some numbers of decimal places the simulations worked fine, with others, the initial assemby failed.
Well, the problem was in my code. I was rounding all the variables but one, and this was breaking the initial assemby. The problem has been solved and the "V2 engine" example now runs smootly. I have uploaded the example to the Gitlab of the project, in case you want to try it.
Cheers.
Cheers.
- OficineRobotica
Your work and what can be achieved with your workbench is amazing. Just WOW.
P.S. You can embed videos here on the forum like this:
[video]https://your_video_link[/video]
Best regards and keep up the good work.
Check out my Youtube channel at: https://www.youtube.com/@OficineRobotica
Thanks!OficineRobotica wrote: ↑Wed Mar 10, 2021 5:01 amYour work and what can be achieved with your workbench is amazing. Just WOW.
I have made a few changes that make it easier to work with "drive hinge" joints. Still not perfect, but now it is possible to put together simulations with a lot of these kind of joints. So far this is the most complicated simulation I have achieved. All together it has 29 bodies and 49 joints...
Here is my first "real-world" application example. I found a quite detailed model of one of those massive KUKA robots on grabcad, and fortunately the author uploaded a .step file, so I was able to import it into FreeCAD.
The example is as follows: Asumming most of the robot´s parts have the average density of steel, and given a certain set of motions of the robot´s joints, calculate: a) the direct kinematics (the position and orientation of the end effector asfunction of time). b) the reaction forces that the joints will have to withstand.
Here is the simulation using my workbench:
This is the first time I test this workbench with a "real world" example. The plan now is to try more examples like this, and document them.
I will also start working on the integration of hydraulic and electric nodes, as I test the workbench with some more examples like this one...
The example will be on Gitlab.
Hi
I have Freecad 0.19.24276 as per below on Win 10.
I have been trying unsuccessfully to install the workbench FreeCAD-MBDyn dynamics workbench.
I've followed the readme and copied the unzipped folder into the Mod folder as instructed.
Everytime I open the Dynamics workbench, I get the Workbench Failure "No Module named 'sympy"" as below.
Is this a case of installing sympy?
I have installed sympy on C using the Anaconda package but that did not help. (Anaconda installed Sympy V1.6.2)
Can anyone help? I have read though the 26 pages of this forum post but to no avail.
Thanks for reading.
12:12:18 No module named 'sympy'
12:12:18 Traceback (most recent call last):
File "<string>", line 361, in Initialize
File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
File "C:\Program Files\FreeCAD 0.19\Mod\freecad-mbdyn-dynamics-workbench-master\MBdynGui.py", line 32, in <module>
from dynamics import Dynamics
File "C:\Program Files\FreeCAD 0.19\Mod\freecad-mbdyn-dynamics-workbench-master\dynamics.py", line 39, in <module>
from revolutepin import Revolutepin
File "C:\Program Files\FreeCAD 0.19\Mod\freecad-mbdyn-dynamics-workbench-master\revolutepin.py", line 50, in <module>
from sympy import Point3D, Line3D
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Thanks for reading.
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Hello.
It seems that the latest version of FreeCAD does not come with SymPy. SymPy is a library my workbench uses for some calculations of orientations, etc:
https://www.sympy.org/en/index.html
All you have to do is install SymPy, but remember that FreeCAD comes with its own Python, so you will have to install SymPy in whatever location FreeCAD´s Python is...
