FreeCAD as pre-post processor for MBDyn
vocx
Re: FreeCAD as pre-post procesor for MBDyn
Postby vocx » Tue Sep 10, 2019 5:21 pm
mfasano wrote:
Tue Sep 10, 2019 1:23 pm
In this thread https://forum.freecadweb.org/viewtopic.php?t=6836 it says the Solid.MatrixOfInertia() method gives units of l^5; this you multipy by the uniform density to get moment of inertia.
Okay, so from this reply, it seems the units are "mm" and "kg" for length and mass, and the others follow from there.
shoogen wrote:
Tue Jun 17, 2014 4:29 pm
I would just pretend that you get a specific moment of inertia (L^5) / (mm^5).
Then you multiply it by some density (M L^-3) / (kg mm^-3) and get your usual Moment of inertia (M L^2) in (kg mm²)
microelly2
Postby microelly2 » Wed Sep 11, 2019 10:52 am
I moved the topic to FEM.
josegegas
Postby josegegas » Wed Sep 11, 2019 11:48 am
Previously only the "revolute pin" joint was included. A bit of progress made today: added the "revolute hinge" joint, which allows linking two solid bodies. Made the classic double pendulum simulation. See the reaction forces on the revolute pin joint :)
https://www.youtube.com/watch?v=Nv5qaQj ... e=youtu.be
bernd
Postby bernd » Wed Sep 11, 2019 12:23 pm
FreeCAD has a unit system. You can get any (im implemented) attribut in any unit (if implemented) you like
see https://forum.freecadweb.org/viewtopic. ... 84#p333484
The moment of inertia might not be supported ATM. Since standad unit is mm it will be mm.
bernd
Postby bernd » Wed Sep 11, 2019 12:24 pm
in the regard of a new solver ...
Before a new solver runs with FreeCAD FEM the new solver needs to be implemented in FreeCAD FEM. As an example have a look at the implementation of oofem solver in FreeCAD FEM.
https://github.com/berndhahnebach/FreeC ... s/femoofem
mainly what FreeCAD FEM does:
- writes an solver input file
- executes the solver
- reads the results
The biggest part is the input file. Since every solver has its own input file format this usually needs to be implemented.
mfasano
Postby mfasano » Wed Sep 11, 2019 12:36 pm
MBDyn needs to be run from a terminal. Is there a way to run a shell script from python?
josegegas
Postby josegegas » Wed Sep 11, 2019 12:40 pm
- reads the results
This is exactly what I'm doing. FreeCAD writes the input file for MBDyn, execute MBDyn, and then simply read the results to animate the model. The beauty of this is that all the information, such as center of mass of each body, inertia moments, positions and orientations, all this stuff (needed for the input file) can be obtained from the FreeCAD model. This saves the user so much work in writing input files manually. Also, being able to visualize the results with just a click, and get an animation and plots, is fantastically handy. What the people using MBDyn normally do is use Matlab to program an animation and/or plot results. FreeCAD can do this without programing, much easier and faster.
josegegas
Postby josegegas » Wed Sep 11, 2019 12:45 pm
Yep. I've don this. So that MBDyn can be executed from FreeCAD with a click...
bernd
Postby bernd » Wed Sep 11, 2019 12:58 pm
FreeCAD FEM is set up to do run the solver as external binaries. This including some smart methods fr solver handling. Adding a new solver and run this solver are just a few lines of code. The big part is writing the input file for a new solver.
- adding the solver object: https://github.com/berndhahnebach/FreeC ... 41bb58ca99
- adding a new task and writer for the new solver: https://github.com/berndhahnebach/FreeC ... ce313d833d
- run the solver https://github.com/berndhahnebach/FreeC ... #L147-L154
- start to implement the real writer
mfasano
Postby mfasano » Wed Sep 11, 2019 1:39 pm
From the video it looks like you open shell and run a command.
