It looks like femutils imports run which tries to import femutils?
FEM WB fails to load : master 9/9/19
Re: FEM WB fails to load : master 9/9/19
"fight the good fight"
would someone give it a try with the fix?
Still fails. Compiled right now.
>>> import Fem
>>> import femtools.femutils
File "<stdin>", line 1, in <module>
File "/opt/freecad-build-vocx/Mod/Fem/femtools/femutils.py", line 35, in <module>
from femsolver.run import _getUniquePath as getUniquePath
File "/opt/freecad-build-vocx/Mod/Fem/femsolver/run.py", line 35, in <module>
import femtools.femutils as femutils
AttributeError: module 'femtools' has no attribute 'femutils'
>>> App.Version()
['0', '19', '18159 (Git)', 'git://github.com/FreeCAD/FreeCAD.git master', '2019/09/10 05:47:26', 'master', '818c3df49cc400222aa862cb19439e65ac6b4450']
building now.
why are you not able to reproduce this , it seems to hit multiple linux distros, win and MacOs.
If I switch to Sketcher WB and double click on a sketch?
File "~/master-build/Mod/Show/TempoVis.py", line 28, in <module>
from . import Containers
<type 'exceptions.ImportError'>: cannot import name Containers
ViewProviderSketch::setEdit: could not import Show module. Visibility automation will not work.
So you are only doing one build on one platform, that is why you cannot reproduce it. No one expects you have 6 different PCs + a Mac but if you had at least some different builds on your platform it may help pinpoint the key factor. Maybe qt or python versions.
It does not seem to be some corner case of one or two users having a rather unusual config. , it is hitting all platforms. It seems your config is the odd one where it does work.
There is a small number of commits which have gone through in the last few days and a good guess could be made as to which ones caused this issue.
Maybe some of those could be walked back so the we get a working master until this is fixed.
>>> import Fem
>>> import femtools
>>> ### Begin command Std_Workbench
>>> Gui.activateWorkbench("FemWorkbench")
>>> ### End command Std_Workbench
there still seam to be a problem on windows. Just pushed another fix ... git commit a3f5a71 would be cool of someone on windows could give it a try ...
unit test still fail on windows ... https://travis-ci.org/FreeCAD/FreeCAD/b ... tification and https://api.travis-ci.org/v3/job/583254733/log.txtbernd wrote: ↑Tue Sep 10, 2019 4:23 pm there still seam to be a problem on windows. Just pushed another fix ... git commit a3f5a71 would be cool of someone on windows could give it a try ...
