FEM constraints closed (assembly) models
Jee-Bee
Postby Jee-Bee » Fri Sep 27, 2019 10:24 am
I have running into a issue with FEM and part design/ step file assemblies
I have in the example a b box with a cover. and i want to create a constraint on the inside of the cover. then i run into one of this two problems:
When let it multiple bodies i'm able to create a constraint on the inside of the cover but i'm not able to make a mesh of all the objects.
When create a compount of all the bodies i'm unable to add a constraint on the inside of the cover (unamble to select or see this face solo) but i'm able to create a mesh of all of this.
Creating first the constraints and make a compount afterwards break the selected faces so don't works eighter...
Anybody tips or tricks how to resolve this?
Box_no_compount.FCStd
(117.12 KiB) Downloaded 17 times
Box_compount.FCStd
(133.21 KiB) Downloaded 20 times
openBrain
Re: FEM constraints closed (assembly) models
Postby openBrain » Sun Sep 29, 2019 3:08 pm
With the help of Selection View with Picked Objets, you can reach every face of the compound (even hidden once). ;)
Jee-Bee
Postby Jee-Bee » Mon Sep 30, 2019 11:12 am
edit i dit something wrong
