[Fixed]Can not set material: "Not known problem"
reox
Postby reox » Wed Oct 30, 2019 5:07 pm
I try to set a material for a solid in the FEM workbench (Create a FEM Material for solid -> choose Material card -> click OK), but no matter what material I choose from the list, I get this error message:
In the log I see:
choose_material in FEM material task panel:
    /usr/share/freecad-daily/Mod/Material/StandardMaterial/Steel-1C22.FCMat
ThermalConductivity not found in material data of: 1C22
SpecificHeat not found in material data of: 1C22
Zero ThermalConductivity value. This parameter is not saved in the material data.
Zero SpecificHeat value. This parameter is not saved in the material data.
<Exception> syntax error
Parameter: ThermalExpansionCoefficient --> value: 0.000011 m/m/K --> Not known problem.
Due to some wrong material quantity units in the changed material data, the task panel changes where not accepted.
What is wrong there? Or is the problem between keyboard and chair?
OS: Debian GNU/Linux bullseye/sid (i3/i3)
Version: 0.19.18640 (Git)
Hash: 2251f53eb5af097cbb4b879af89575132660e541
Python version: 3.7.5
Qt version: 5.12.5
Locale: German/Austria (de_AT)
vocx
Re: Can not set material: "Not known problem"
Postby vocx » Thu Oct 31, 2019 6:10 pm
You should probably ask in the FEM workbench, as it seems the problem is with how the workbench tries to get the material.
Postby Kunda1 » Thu Oct 31, 2019 7:32 pm
Moved to FEM subforum
bernd
Postby bernd » Fri Nov 01, 2019 10:07 am
[/code]
Very strange for me 0.19.18638 works great. There has been no changes in the regard of either materials or FEM material taskpanel lately. The syntax error seams strange to me.
The only difference I am on Buster you on sid. Python verison on Buster is 3.7.3 this should not the problem. Do you find the syntax error or have more information about it.
You may could reduce the material directories to a own directory and only put a few material cards in, just to test.
reox
Postby reox » Fri Nov 01, 2019 12:46 pm
Okay I think I know whats wrong:
I can also reproduce it by using "use Task Panel" and putting any non-zero value into the thermal expansion coeff.
Interestingly, if I put a 1 1/K there, I get this message:
Parameter: ThermalExpansionCoefficient --> value: 1000000.0 um/m/K --> Not known problem.
Which got me thinking... Actually I use the Unit schema for "Metric small parts & CNC"! Switching this to Standard SI units made everything work.
So it looks like the parser for units gets confused when parsing the units when in CNC mode?!
bernd
Postby bernd » Fri Nov 01, 2019 12:59 pm
ok one step further. I changed to this unit system too, still no problems here.
bernd
Postby bernd » Fri Nov 01, 2019 1:01 pm
What I did:
- start FreeCAD
- change in prefs to unit small parts with cnc
- got to FEM wb
- Add an analysis
- add an material
- change to material Steel-1C22.FCMat
works without any problem
reox
Postby reox » Fri Nov 01, 2019 1:40 pm
I tried it again, restart FC, set CNC units, etc.. did the same as you. And it produces the error.
Right now, I'm at
Version: 0.19.18644 (Git)
Hash: 481870be2b48ef95b59acf1440b069d42b6fad23
Qt version: 5.12.5
Maybe I'm missing some build flags? (It is not the offical daily build but my own build)
But I checked the buildlog, there are only warnings (the usual stuff IMO), no errors.
My localization in FC is set to English - maybe this makes a difference?
I even started with a new .FreeCAD folder (which sets my locale by default to German btw) and could reproduce the error there when setting the Units to CNC.
bernd
Postby bernd » Fri Nov 01, 2019 2:01 pm
how about the other unit systems ...
reox
Postby reox » Fri Nov 01, 2019 4:36 pm
tested all of them:
Standard ... works
MKS ... works
US customary ... error
Imperial decimal ... error
Building euro ... error
Building US ... error
CNC ... error
Imperial civial ... error
btw you can debug this in the python console it looks like:
>>> from FreeCAD import Units
>>> Units.ThermalExpansionCoefficient
Unit: 1/K (0,0,0,0,-1,0,0,0) [ThermalExpansionCoefficient]
>>> quantity = Units.Quantity(1, Units.ThermalExpansionCoefficient)
>>> user_prefered_unit = quantity.getUserPreferred()[2]
>>> user_prefered_unit
'm/m/K'
>>> param_value = Units.Quantity('0.0001 m/m/K')
>>> Gui.runCommand('Std_DlgPreferences',0)   # Changed from MKS to CNC
>>> user_prefered_unit
'1/K'
>>> param_value.getValueAs(user_prefered_unit)
Base.FreeCADError: syntax error
So somehow the meters per meters get replaced by 1, then it fails.
Especially if you do stuff like:
>>> quantity.getValueAs('m/m/K')
1
>>> quantity.getValueAs('1/K')
>>> quantity.getValueAs('kg/kg/K')
1
So if you use ANY unit which cancels to 1 it works. But if you use 1 instead, it fails.
Interestingly, this works too:
>>> quantity.getValueAs('K^-1')
1
