HARMONIC - *MODAL DAMPING
pecmichal
Postby pecmichal » Fri Nov 08, 2019 9:17 pm
I am facing problem running *STEADY STATE DYNAMICS (HARMONIC) analysis with *BASE MOTION and *MODAL DAMPING with critical damping factor all together. Do you have any ideas how to make it works? Base motion command is available from 2.15 ccx version. If I change *MODAL DAMPING to RAYLEIGH, it works.
I am enclosing testing file which I am trying to run (just change extension).
Thank you in advance,
pecmichal
test_1.txt
(56.59 KiB) Downloaded 18 times
Jee-Bee
Re: HARMONIC - *MODAL DAMPING
Postby Jee-Bee » Mon Nov 11, 2019 8:47 am
Do you have a FreeCAD file?
