Elmer electrostatics FEM
TadasK
Postby TadasK » Fri Dec 06, 2019 6:42 pm
Greetings,
Could somebody provide a description or a video of using Freecad for electrostatic problems?
My main concerns:
1. How to model an enclosed far-field sphere?
2. How to define the relative permittivities of the surfaces?
Thanks in advance,
Ted
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: Lithuanian/Lithuania (lt_LT)
bernd
Re: Elmer electrostatics FEM
Postby bernd » Mon Dec 09, 2019 1:13 pm
inside this huge topic are numerous examples. There should be one with electrostatics as well. https://forum.freecadweb.org/viewtopic. ... &start=270
These guys know how to do this in FreeCAD FEM.
m42kus wrote: ping
HoWil wrote: ping
TadasK
Postby TadasK » Tue Dec 10, 2019 8:22 pm
Thank you bernd.
m42kus wrote: ping
HoWil wrote: ping
bernd
Postby bernd » Tue Dec 10, 2019 10:07 pm
have you read https://forum.freecadweb.org/viewtopic.php?f=18&t=12212
I would recommend to use 0.19 for FEM.
bernd
Postby bernd » Fri Dec 13, 2019 7:25 am
HoWil
Postby HoWil » Sat Dec 14, 2019 7:50 pm
Hi Bernd,
I tried to run the model from here (https://forum.freecadweb.org/viewtopic. ... 07#p233996) and found some problems.
The main problem is that the vtk-import seems to be broken in 0.19.
You can test this by opening the model called "FemCalculixCantilever3D_newSolver.FCStd " from the startpage.
+Activate the analysis
+Delete "SolverElmerResult"
+Rerun the simulation with "SolverElmer" (write and rerun)
+Open the new vtk-pipeline -> Mode Surface .... now you see that there is no data included in the vtk-object.
Nevertheless, a result object is generated by elmer. it is locate in the "working directory" folder specified in the analysis object.
Hope this can be easily fixed.
Will try to recreate the model in 0.18
BR,
HoWil
OS: Ubuntu 18.04.3 LTS (GNOME/gnome)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
HoWil
Postby HoWil » Sat Dec 14, 2019 7:57 pm
Its the same with a newly built model in
Version: 0.18.4.
Python version: 2.7.15+
Qt version: 5.9.5
The standard model called "FemCalculixCantilever3D_newSolver.FCStd " from the startpage does not work at all with my 0.18.
HoWil
Postby HoWil » Sun Dec 15, 2019 1:19 pm
m42kus wrote: ping
Did you experience any if problems above during your last Gsoc?
bernd
Postby bernd » Mon Dec 16, 2019 9:04 am
on 0.19 dev version
- run elmer analysis
- close the solver taskpanel
- left click in the white area of the tree view and the result object will be there
- I have no idea why the tree view does not get udated
Would you confirm if it works for you.
bernd
Postby bernd » Mon Dec 16, 2019 3:52 pm
What make me thinking of a problem is there are only displacements in the result object. No stress at all?! IMHO there was more than just the displacement?
remove txt
case0001.vtu.txt
(42.83 KiB) Downloaded 6 times
