Elmer electrostatics FEM
HoWil
Re: Elmer electrostatics FEM
Postby HoWil » Sun Feb 16, 2020 8:00 pm
bernd wrote:
Sun Feb 16, 2020 7:26 pm
git commit a758941
The important part is the
if obj.PotentialEnabled:
which is in the above commit missing :!:
The second if....
if hasattr(obj, 'Potential'):
is more a check if the later on needed information is available.
bernd
Postby bernd » Sun Feb 16, 2020 9:13 pm
would you post the whole writer file or at least all the lines in the area which should be changed.
HoWil
Postby HoWil » Mon Feb 17, 2020 6:38 pm
# *   Copyright (c) 2017 Markus Hovorka <m.hovorka@live.de>                 *
# *   This program is free software; you can redistribute it and/or modify  *
# *   it under the terms of the GNU Lesser General Public License (LGPL)    *
# *   as published by the Free Software Foundation; either version 2 of     *
# *   the License, or (at your option) any later version.                   *
# *   for detail see the LICENCE text file.                                 *
# *   This program is distributed in the hope that it will be useful,       *
# *   but WITHOUT ANY WARRANTY; without even the implied warranty of        *
# *   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the         *
# *   GNU Library General Public License for more details.                  *
# *   You should have received a copy of the GNU Library General Public     *
# *   License along with this program; if not, write to the Free Software   *
# *   Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  *
# *   USA        *
__title__ = "FreeCAD FEM solver Elmer writer"
__author__ = "Markus Hovorka"
__url__ = "http://www.freecadweb.org"
## \addtogroup FEM
import os
import os.path
import subprocess
import tempfile
from FreeCAD import Units
from FreeCAD import Console
import Fem
import femtools.femutils as femutils
import femmesh.gmshtools as gmshtools
from .. import settings
from . import sifio
_STARTINFO_NAME = "ELMERSOLVER_STARTINFO"
_SIF_NAME = "case.sif"
_ELMERGRID_IFORMAT = "8"
_ELMERGRID_OFORMAT = "2"
_SOLID_PREFIX = "Solid"
UNITS = {
    "L": "mm",
    "M": "kg",
    "T": "s",
    "I": "A",
    "O": "K",
    "N": "mol",
    "J": "cd",
CONSTS_DEF = {
    "Gravity": "9.82 m/s^2",
    "StefanBoltzmann": "5.67e-8 W/(m^2*K^4)",
    "PermittivityOfVacuum": "8.8542e-12 s^4*A^2/(m*kg)",
    "BoltzmannConstant": "1.3807e-23 J/K",
def getFromUi(value, unit, outputDim):
    quantity = Units.Quantity(str(value) + str(unit))
    return convert(quantity, outputDim)
def convert(quantityStr, unit):
    quantity = Units.Quantity(quantityStr)
    for key, setting in UNITS.items():
        unit = unit.replace(key, setting)
    return float(quantity.getValueAs(unit))
def _getAllSubObjects(obj):
    s = ["Solid" + str(i + 1) for i in range(len(obj.Shape.Solids))]
    s.extend(("Face" + str(i + 1) for i in range(len(obj.Shape.Faces))))
    s.extend(("Edge" + str(i + 1) for i in range(len(obj.Shape.Edges))))
    s.extend(("Vertex" + str(i + 1) for i in range(len(obj.Shape.Vertexes))))
    return s
def getConstant(name, dimension):
    return convert(CONSTS_DEF[name], dimension)
class Writer(object):
    def __init__(self, solver, directory, testmode=False):
        self.analysis = femutils.findAnalysisOfMember(solver)
        self.solver = solver
        self.directory = directory
        self.testmode = testmode
        self._usedVarNames = set()
        self._builder = sifio.Builder()
        self._handledObjects = set()
    def getHandledConstraints(self):
        return self._handledObjects
    def write(self):
        self._handleSimulation()
        self._handleHeat()
        self._handleElasticity()
        self._handleElectrostatic()
        self._handleFluxsolver()
        self._handleFlow()
        self._addOutputSolver()
        self._writeSif()
        self._writeMesh()
        self._writeStartinfo()
    def _writeMesh(self):
        mesh = self._getSingleMember("Fem::FemMeshObject")
        unvPath = os.path.join(self.directory, "mesh.unv")
        groups = []
        groups.extend(self._builder.getBodyNames())
        groups.extend(self._builder.getBoundaryNames())
        self._exportToUnv(groups, mesh, unvPath)
        if self.testmode:
            Console.PrintMessage("We are in testmode ElmerGrid may not be installed.\n")
        else:
            binary = settings.get_binary("ElmerGrid")
            if binary is None:
                raise WriteError("Couldn't find ElmerGrid binary.")
            args = [binary,
                    _ELMERGRID_IFORMAT,
                    _ELMERGRID_OFORMAT,
                    unvPath,
                    "-out", self.directory]
            subprocess.call(args, stdout=subprocess.DEVNULL)
    def _writeStartinfo(self):
        path = os.path.join(self.directory, _STARTINFO_NAME)
        with open(path, "w") as f:
            f.write(_SIF_NAME)
    def _exportToUnv(self, groups, mesh, meshPath):
        unvGmshFd, unvGmshPath = tempfile.mkstemp(suffix=".unv")
        brepFd, brepPath = tempfile.mkstemp(suffix=".brep")
        geoFd, geoPath = tempfile.mkstemp(suffix=".geo")
        os.close(brepFd)
        os.close(geoFd)
        os.close(unvGmshFd)
        tools = gmshtools.GmshTools(mesh)
        tools.group_elements = {g: [g] for g in groups}
        tools.group_nodes_export = False
        tools.ele_length_map = {}
        tools.temp_file_geometry = brepPath
        tools.temp_file_geo = geoPath
        tools.temp_file_mesh = unvGmshPath
        tools.get_dimension()
        tools.get_gmsh_command()
        tools.get_region_data()
        tools.get_boundary_layer_data()
        tools.write_part_file()
        tools.write_geo()
        if self.testmode:
            Console.PrintMessage("We are in testmode, Gmsh may not be installed.\n")
            import shutil
            shutil.copyfile(geoPath, os.path.join(self.directory, "group_mesh.geo"))
        else:
            tools.run_gmsh_with_geo()
            ioMesh = Fem.FemMesh()
            ioMesh.read(unvGmshPath)
            ioMesh.write(meshPath)
        os.remove(brepPath)
        os.remove(geoPath)
        os.remove(unvGmshPath)
    def _handleSimulation(self):
        self._simulation("Coordinate System", "Cartesian 3D")
        self._simulation("Coordinate Mapping", (1, 2, 3))
        self._simulation("Simulation Type", "Steady state")
        self._simulation("Steady State Max Iterations", 1)
        self._simulation("Output Intervals", 1)
        self._simulation("Timestepping Method", "BDF")
        self._simulation("BDF Order", 1)
        self._simulation("Use Mesh Names", True)
        self._simulation(
            self.solver.SteadyStateMaxIterations)
        self._simulation(
            "Steady State Min Iterations",
            self.solver.SteadyStateMinIterations)
    def _handleHeat(self):
        activeIn = []
        for equation in self.solver.Group:
            if femutils.is_of_type(equation, "Fem::FemEquationElmerHeat"):
                if equation.References:
                    activeIn = equation.References[0][1]
                else:
                    activeIn = self._getAllBodies()
                solverSection = self._getHeatSolver(equation)
                for body in activeIn:
                    self._addSolver(body, solverSection)
        if activeIn:
            self._handleHeatConstants()
            self._handleHeatBndConditions()
            self._handleHeatInitial(activeIn)
            self._handleHeatBodyForces(activeIn)
            self._handleHeatMaterial(activeIn)
    def _getHeatSolver(self, equation):
        s = self._createNonlinearSolver(equation)
        s["Equation"] = equation.Name
        s["Procedure"] = sifio.FileAttr("HeatSolve/HeatSolver")
        s["Variable"] = self._getUniqueVarName("Temperature")
        s["Exec Solver"] = "Always"
        s["Stabilize"] = equation.Stabilize
        s["Bubbles"] = equation.Bubbles
        s["Optimize Bandwidth"] = True
        return s
    def _handleHeatConstants(self):
        self._constant(
            "Stefan Boltzmann",
            getConstant("StefanBoltzmann", "M/(O^4*T^3)"))
    def _handleHeatBndConditions(self):
        for obj in self._getMember("Fem::ConstraintTemperature"):
            if obj.References:
                for name in obj.References[0][1]:
                    if obj.ConstraintType == "Temperature":
                        temp = getFromUi(obj.Temperature, "K", "O")
                        self._boundary(name, "Temperature", temp)
                    elif obj.ConstraintType == "CFlux":
                        flux = getFromUi(obj.CFlux, "kg*mm^2*s^-3", "M*L^2*T^-3")
                        self._boundary(name, "Temperature Load", flux)
                self._handled(obj)
        for obj in self._getMember("Fem::ConstraintHeatflux"):
            if obj.References:
                    if obj.ConstraintType == "Convection":
                        film = getFromUi(obj.FilmCoef, "W/(m^2*K)", "M/(T^3*O)")
                        temp = getFromUi(obj.AmbientTemp, "K", "O")
                        self._boundary(name, "Heat Transfer Coefficient", film)
                        self._boundary(name, "External Temperature", temp)
                    elif obj.ConstraintType == "DFlux":
                        flux = getFromUi(obj.DFlux, "W/m^2", "M*T^-3")
                        self._boundary(name, "Heat Flux BC", True)
                        self._boundary(name, "Heat Flux", flux)
                self._handled(obj)
    def _handleHeatInitial(self, bodies):
        obj = self._getSingleMember("Fem::ConstraintInitialTemperature")
        if obj is not None:
            for name in bodies:
                temp = getFromUi(obj.initialTemperature, "K", "O")
                self._initial(name, "Temperature", temp)
            self._handled(obj)
    def _handleHeatBodyForces(self, bodies):
        obj = self._getSingleMember("Fem::ConstraintBodyHeatSource")
        if obj is not None:
            for name in bodies:
                heatSource = getFromUi(obj.HeatSource, "W/kg", "L^2*T^-3")
                # according Elmer forum W/kg is correct
                # http://www.elmerfem.org/forum/viewtopic.php?f=7&t=1765
                # 1 watt = kg * m2 / s3 ... W/kg = m2 / s3
                self._bodyForce(name, "Heat Source", heatSource)
            self._handled(obj)
    def _handleHeatMaterial(self, bodies):
        tempObj = self._getSingleMember("Fem::ConstraintInitialTemperature")
        if tempObj is not None:
            refTemp = getFromUi(tempObj.initialTemperature, "K", "O")
            for name in bodies:
                self._material(name, "Reference Temperature", refTemp)
        for obj in self._getMember("App::MaterialObject"):
            m = obj.Material
            refs = (
                if obj.References
                else self._getAllBodies())
            for name in (n for n in refs if n in bodies):
                self._material(
                    name, "Density",
                    self._getDensity(m))
                self._material(
                    name, "Heat Conductivity",
                    convert(m["ThermalConductivity"], "M*L/(T^3*O)"))
                self._material(
                    name, "Heat Capacity",
                    convert(m["SpecificHeat"], "L^2/(T^2*O)"))
    def _handleElectrostatic(self):
        activeIn = []
            if femutils.is_of_type(equation, "Fem::FemEquationElmerElectrostatic"):
                else:
                solverSection = self._getElectrostaticSolver(equation)
        if activeIn:
            self._handleElectrostaticConstants()
            self._handleElectrostaticBndConditions()
            # self._handleElectrostaticInitial(activeIn)
            # self._handleElectrostaticBodyForces(activeIn)
            self._handleElectrostaticMaterial(activeIn)
    def _getElectrostaticSolver(self, equation):
        s = self._createLinearSolver(equation)
        s["Equation"] = "Stat Elec Solver"  # equation.Name
        s["Procedure"] = sifio.FileAttr("StatElecSolve/StatElecSolver")
        s["Variable"] = self._getUniqueVarName("Potential")
        s["Variable DOFs"] = 1
        s["Calculate Electric Field"] = equation.CalculateElectricField
        # s["Calculate Electric Flux"] = equation.CalculateElectricFlux
        s["Calculate Electric Energy"] = equation.CalculateElectricEnergy
        s["Calculate Surface Charge"] = equation.CalculateSurfaceCharge
        s["Calculate Capacitance Matrix"] = equation.CalculateCapacitanceMatrix  # Howil added
        s["Displace mesh"] = False
        return s
    def _handleElectrostaticConstants(self):
        self._constant(
            "Permittivity Of Vacuum",
            getConstant("PermittivityOfVacuum", "T^4*I^2/(L*M)"))
    def _handleElectrostaticMaterial(self, bodies):
            m = obj.Material
            refs = (
                if obj.References
                if "RelativePermittivity" in m:
                    self._material(
                        name, "Relative Permittivity",
                        float(m["RelativePermittivity"]))
    def _handleElectrostaticBndConditions(self):
        for obj in self._getMember("Fem::ConstraintElectrostaticPotential"):
            if obj.References:
                    if obj.PotentialEnabled:  # HoWil: was added
                        if hasattr(obj, 'Potential'):  # HoWil:has to be changed from " if obj.Potential:"
                            potential = getFromUi(obj.Potential, "V", "M*L^2/(T^3 * I)")
                            self._boundary(name, "Potential", potential)
                    if obj.PotentialConstant:
                        self._boundary(name, "Potential Constant", True)
                self._handled(obj)
    def _handleFluxsolver(self):
        activeIn = []
            if femutils.is_of_type(equation, "Fem::FemEquationElmerFluxsolver"):
                else:
                solverSection = self._getFluxsolverSolver(equation)
    def _getFluxsolverSolver(self, equation):
        s["Equation"] = "Flux Solver"  # equation.Name
        s["Procedure"] = sifio.FileAttr("FluxSolver/FluxSolver")
        s["Flux Variable"] = equation.FluxVariable
        s["Calculate Flux"] = equation.CalculateFlux
        s["Calculate Grad"] = equation.CalculateGrad
        return s
    def _handleElasticity(self):
        activeIn = []
            if femutils.is_of_type(equation, "Fem::FemEquationElmerElasticity"):
                else:
                solverSection = self._getElasticitySolver(equation)
        if activeIn:
            self._handleElasticityConstants()
            self._handleElasticityBndConditions()
            self._handleElasticityInitial(activeIn)
            self._handleElasticityBodyForces(activeIn)
            self._handleElasticityMaterial(activeIn)
    def _getElasticitySolver(self, equation):
        s["Procedure"] = sifio.FileAttr("StressSolve/StressSolver")
        s["Variable"] = self._getUniqueVarName("Displacement")
        s["Variable DOFs"] = 3
        s["Eigen Analysis"] = equation.DoFrequencyAnalysis
        s["Eigen System Values"] = equation.EigenmodesCount
        s["Calculate Strains"] = equation.CalculateStrains
        s["Calculate Stresses"] = equation.CalculateStresses
        s["Calculate Principal"] = equation.CalculatePrincipal
        s["Calculate Pangle"] = equation.CalculatePangle
        return s
    def _handleElasticityConstants(self):
        pass
    def _handleElasticityBndConditions(self):
        for obj in self._getMember("Fem::ConstraintPressure"):
            if obj.References:
                    pressure = getFromUi(obj.Pressure, "MPa", "M/(L*T^2)")
                    if not obj.Reversed:
                        pressure *= -1
                    self._boundary(name, "Normal Force", pressure)
                self._handled(obj)
        for obj in self._getMember("Fem::ConstraintFixed"):
            if obj.References:
                    self._boundary(name, "Displacement 1", 0.0)
                    self._boundary(name, "Displacement 2", 0.0)
                    self._boundary(name, "Displacement 3", 0.0)
                self._handled(obj)
        for obj in self._getMember("Fem::ConstraintForce"):
            if obj.References:
                    force = getFromUi(obj.Force, "N", "M*L*T^-2")
                    self._boundary(name, "Force 1", obj.DirectionVector.x * force)
                    self._boundary(name, "Force 2", obj.DirectionVector.y * force)
                    self._boundary(name, "Force 3", obj.DirectionVector.z * force)
                    self._boundary(name, "Force 1 Normalize by Area", True)
                    self._boundary(name, "Force 2 Normalize by Area", True)
                    self._boundary(name, "Force 3 Normalize by Area", True)
                self._handled(obj)
        for obj in self._getMember("Fem::ConstraintDisplacement"):
            if obj.References:
                    if not obj.xFree:
                        self._boundary(
                            name, "Displacement 1", obj.xDisplacement * 0.001)
                    elif obj.xFix:
                    if not obj.yFree:
                        self._boundary(
                            name, "Displacement 2", obj.yDisplacement * 0.001)
                    elif obj.yFix:
                    if not obj.zFree:
                        self._boundary(
                            name, "Displacement 3", obj.zDisplacement * 0.001)
                    elif obj.zFix:
                self._handled(obj)
    def _handleElasticityInitial(self, bodies):
        pass
    def _handleElasticityBodyForces(self, bodies):
        obj = self._getSingleMember("FemConstraintSelfWeight")
        if obj is not None:
            for name in bodies:
                gravity = getConstant("Gravity", "L/T^2")
                m = self._getBodyMaterial(name).Material
                densityQuantity = Units.Quantity(m["Density"])
                dimension = "M/L^3"
                if name.startswith("Edge"):
                    # not tested, but it seems needed
                    # because density does not exist (IMHO, bernd)
                    density = None
                    if density:
                        density.Unit = Units.Unit(-2, 1)
                    dimension = "M/L^2"
                density = convert(densityQuantity, dimension)
                force1 = gravity * obj.Gravity_x * density
                force2 = gravity * obj.Gravity_y * density
                force3 = gravity * obj.Gravity_z * density
                self._bodyForce(name, "Stress Bodyforce 1", force1)
                self._bodyForce(name, "Stress Bodyforce 2", force2)
                self._bodyForce(name, "Stress Bodyforce 3", force3)
            self._handled(obj)
    def _getBodyMaterial(self, name):
            if not obj.References or name in obj.References[0][1]:
                return obj
        return None
    def _handleElasticityMaterial(self, bodies):
            for name in bodies:
            m = obj.Material
            refs = (
                if obj.References
                self._material(
                    name, "Density",
                self._material(
                    name, "Youngs Modulus",
                    self._getYoungsModulus(m))
                self._material(
                    name, "Poisson ratio",
                    float(m["PoissonRatio"]))
                self._material(
                    name, "Heat expansion Coefficient",
                    convert(m["ThermalExpansionCoefficient"], "O^-1"))
    def _getDensity(self, m):
        density = convert(m["Density"], "M/L^3")
        if self._getMeshDimension() == 2:
            density *= 1e3
        return density
    def _getYoungsModulus(self, m):
        youngsModulus = convert(m["YoungsModulus"], "M/(L*T^2)")
            youngsModulus *= 1e3
        return youngsModulus
    def _handleFlow(self):
        activeIn = []
            if femutils.is_of_type(equation, "Fem::FemEquationElmerFlow"):
                else:
                solverSection = self._getFlowSolver(equation)
        if activeIn:
            self._handleFlowConstants()
            self._handleFlowBndConditions()
            self._handleFlowInitialVelocity(activeIn)
            # self._handleFlowInitial(activeIn)
            # self._handleFlowBodyForces(activeIn)
            self._handleFlowMaterial(activeIn)
            self._handleFlowEquation(activeIn)
    def _getFlowSolver(self, equation):
        s["Equation"] = "Navier-Stokes"
        # s["Equation"] = equation.Name
        s["Procedure"] = sifio.FileAttr("FlowSolve/FlowSolver")
        return s
    def _handleFlowConstants(self):
        self._constant("Gravity", (0.0, -1.0, 0.0, gravity))
    def _handleFlowMaterial(self, bodies):
            for name in bodies:
            m = obj.Material
            refs = (
                if obj.References
                if "Density" in m:
                    self._material(
                        name, "Density",
                if "ThermalConductivity" in m:
                    self._material(
                if "KinematicViscosity" in m:
                    density = self._getDensity(m)
                    kViscosity = convert(m["KinematicViscosity"], "L^2/T")
                    self._material(
                        name, "Viscosity", kViscosity * density)
                if "ThermalExpansionCoefficient" in m:
                    value = convert(m["ThermalExpansionCoefficient"], "O^-1")
                    if value > 0:
                        self._material(
                            name, "Heat expansion Coefficient", value)
                if "ReferencePressure" in m:
                    pressure = convert(m["ReferencePressure"], "M/(L*T^2)")
                    self._material(name, "Reference Pressure", pressure)
                if "SpecificHeatRatio" in m:
                    self._material(
                        name, "Specific Heat Ratio",
                        float(m["SpecificHeatRatio"]))
                if "CompressibilityModel" in m:
                    self._material(
                        name, "Compressibility Model",
                        m["CompressibilityModel"])
    def _handleFlowInitialVelocity(self, bodies):
        obj = self._getSingleMember("Fem::ConstraintInitialFlowVelocity")
        if obj is not None:
            for name in bodies:
                if obj.VelocityXEnabled:
                    velocity = getFromUi(obj.VelocityX, "m/s", "L/T")
                    self._initial(name, "Velocity 1", velocity)
                if obj.VelocityYEnabled:
                    velocity = getFromUi(obj.VelocityY, "m/s", "L/T")
                    self._initial(name, "Velocity 2", velocity)
                if obj.VelocityZEnabled:
                    velocity = getFromUi(obj.VelocityZ, "m/s", "L/T")
                    self._initial(name, "Velocity 3", velocity)
            self._handled(obj)
    def _handleFlowBndConditions(self):
        for obj in self._getMember("Fem::ConstraintFlowVelocity"):
            if obj.References:
                        self._boundary(name, "Velocity 1", velocity)
                        self._boundary(name, "Velocity 2", velocity)
                        self._boundary(name, "Velocity 3", velocity)
                    if obj.NormalToBoundary:
                        self._boundary(name, "Normal-Tangential Velocity", True)
                self._handled(obj)
    def _handleFlowEquation(self, bodies):
        for b in bodies:
            self._equation(b, "Convection", "Computed")
    def _createLinearSolver(self, equation):
        s = sifio.createSection(sifio.SOLVER)
        s.priority = equation.Priority
        s["Linear System Solver"] = equation.LinearSolverType
        if equation.LinearSolverType == "Direct":
            s["Linear System Direct Method"] = \
                equation.LinearDirectMethod
        elif equation.LinearSolverType == "Iterative":
            s["Linear System Iterative Method"] = \
                equation.LinearIterativeMethod
            if equation.LinearIterativeMethod == "BiCGStabl":
                s["BiCGstabl polynomial degree"] = \
                    equation.BiCGstablDegree
            s["Linear System Max Iterations"] = \
                equation.LinearIterations
            s["Linear System Convergence Tolerance"] = \
                equation.LinearTolerance
            s["Linear System Preconditioning"] = \
                equation.LinearPreconditioning
        s["Steady State Convergence Tolerance"] = \
            equation.SteadyStateTolerance
        s["Linear System Abort Not Converged"] = False
        s["Linear System Residual Output"] = 1
        s["Linear System Precondition Recompute"] = 1
        return s
    def _createNonlinearSolver(self, equation):
        s["Nonlinear System Max Iterations"] = \
            equation.NonlinearIterations
        s["Nonlinear System Convergence Tolerance"] = \
            equation.NonlinearTolerance
        s["Nonlinear System Relaxation Factor"] = \
            equation.RelaxationFactor
        s["Nonlinear System Newton After Iterations"] = \
            equation.NonlinearNewtonAfterIterations
        s["Nonlinear System Newton After Tolerance"] = \
            equation.NonlinearNewtonAfterTolerance
        return s
    def _getUniqueVarName(self, varName):
        postfix = 1
        if varName in self._usedVarNames:
            varName += "%2d" % postfix
        while varName in self._usedVarNames:
            postfix += 1
            varName = varName[:-2] + "%2d" % postfix
        self._usedVarNames.add(varName)
        return varName
    def _getAllBodies(self):
        obj = self._getSingleMember("Fem::FemMeshObject")
        bodyCount = 0
        prefix = ""
        if obj.Part.Shape.Solids:
            prefix = "Solid"
            bodyCount = len(obj.Part.Shape.Solids)
        elif obj.Part.Shape.Faces:
            prefix = "Face"
            bodyCount = len(obj.Part.Shape.Faces)
        elif obj.Part.Shape.Edges:
            prefix = "Edge"
            bodyCount = len(obj.Part.Shape.Edges)
        return [prefix + str(i + 1) for i in range(bodyCount)]
    def _getMeshDimension(self):
            return 3
            return 2
            return 1
        return None
    def _addOutputSolver(self):
        s["Equation"] = "ResultOutput"
        s["Exec Solver"] = "After simulation"
        s["Procedure"] = sifio.FileAttr("ResultOutputSolve/ResultOutputSolver")
        s["Output File Name"] = sifio.FileAttr("case")
        s["Vtu Format"] = True
        for name in self._getAllBodies():
            self._addSolver(name, s)
    def _writeSif(self):
        sifPath = os.path.join(self.directory, _SIF_NAME)
        with open(sifPath, "w") as fstream:
            sif = sifio.Sif(self._builder)
            sif.write(fstream)
    def _handled(self, obj):
        self._handledObjects.add(obj)
    def _simulation(self, key, attr):
        self._builder.simulation(key, attr)
    def _constant(self, key, attr):
        self._builder.constant(key, attr)
    def _initial(self, body, key, attr):
        self._builder.initial(body, key, attr)
    def _material(self, body, key, attr):
        self._builder.material(body, key, attr)
    def _equation(self, body, key, attr):
        self._builder.equation(body, key, attr)
    def _bodyForce(self, body, key, attr):
        self._builder.bodyForce(body, key, attr)
    def _addSolver(self, body, solverSection):
        self._builder.addSolver(body, solverSection)
    def _boundary(self, boundary, key, attr):
        self._builder.boundary(boundary, key, attr)
    def _addSection(self, section):
        self._builder.addSection(section)
    def _getMember(self, t):
        return femutils.get_member(self.analysis, t)
    def _getSingleMember(self, t):
        return femutils.get_single_member(self.analysis, t)
class WriteError(Exception):
    pass
HoWil
Postby HoWil » Tue Feb 18, 2020 6:45 am
I also have implemented the farfield/electric-infinity boundary condition and the settings for calculating the capacitance matrix. This needs some extra polish which I will be able to do within a few days. The current files can be found attached.
I struggle a bit with git and want to use this to document the procedure (again...and again I know). Where do I find documentation for the steps after cloning (git clone https://github.com/berndhahnebach/FreeCAD_bhb) like connecting my github-user and doing a commit?
InfinityBC_CapacitanceMatrix.zip
(12.06 KiB) Downloaded 6 times
bernd
Postby bernd » Tue Feb 18, 2020 7:20 am
HoWil
Postby HoWil » Wed Feb 19, 2020 6:52 am
Hi Bernd,
Can you please test my electrostatics_BSs branch at:
https://github.com/HoWilgh/FreeCAD/tree ... tatics_BCs
I compiled it with "cmake -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3 ../freecad-source"
and get on Ubuntu 18.04 a
/freecad-build/bin$ ./FreeCAD
FreeCAD 0.19, Libs: 0.19R19655 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Aborted (core dumped)
without any further information.
HoWil
Postby HoWil » Thu Feb 20, 2020 6:37 am
git commit fc9c8a4fe
Hi Bernd,
Please add
https://github.com/berndhahnebach/FreeCAD_bhb/pull/62
BR
HoWil
Postby HoWil » Thu Feb 20, 2020 6:42 am
Next steps just for documentation:
  • code cleanup and adding test (if capacitance matrix selected in equation than..
  • add the 'constant' 'Permittivity Of Vacuum' into the equation dialogue
  • add the equation 'Electric Force' and according boundary conditions (see https://www.nic.funet.fi/index/elmer/do ... nonGUI.pdf page 30)
bernd
Postby bernd » Thu Feb 20, 2020 5:20 pm
is this for the example posted earlier in this topic? Does this run? I would like to add such example to the official FreeCAD FEM examples. I have added a few allready ... https://github.com/FreeCAD/FreeCAD/tree ... emexamples all coded in Python :D
HoWil
Postby HoWil » Thu Feb 20, 2020 5:53 pm
Yes
Does this run?
95% of it. If this merge is done than I will add point 1+2 and the model/example of the tutorial will be finished.
Point 3 is an extra which is interesting for me.
BR
