Neg. Jacobians at Surface 2nd Order Elements
UR_
Postby UR_ » Mon Dec 16, 2019 6:45 pm
bernd wrote: :bell:
Hi bernd,
as well known, neg. jacobians occur very often and most of them appears near part's surface while using elements of 2nd order.
Gmsh offers a parameter to suppress some of them.
shape2mesh.geo:
Mesh.SecondOrderLinear = 1; // Second order nodes are created by linear interpolation instead curvilinear
Usually Gmsh tries to follow part's surface as close as possible. Therefore midpoints of surface 2nd order elements are curvilinear moved to match
desired curvature of part.
Sometimes bad shaped tetrahedrons (high edge ratio) hit limit, resulting in neg. jacobians.
Above mentioned parameter stops element distortion and ensures straight elements at surface with linear interpolated midpoints.
Therefore I introduced a new property to FEMmeshGmsh
Screenshot 003.png (4.38 KiB) Viewed 654 times
to get above shown shape2mesh.geo layout
_FemMeshGmsh.py:
diff U C:/Users/aio/FreeCADcode/src/Mod/Fem/femobjects/_FemMeshGmsh.py C:/Users/aio/Miniconda3/envs/freecad/Library/Mod/Fem/femobjects/_FemMeshGmsh.py
--- C:/Users/aio/FreeCADcode/src/Mod/Fem/femobjects/_FemMeshGmsh.py	Mon Dec 16 18:45:08 2019
+++ C:/Users/aio/Miniconda3/envs/freecad/Library/Mod/Fem/femobjects/_FemMeshGmsh.py	Mon Dec 16 14:09:13 2019
@@ -177,0 +178,8 @@
+            "App::PropertyBool",
+            "SecondOrderLinear",
+            "FEM Gmsh Mesh Params",
+            "Second order nodes are created by linear interpolation"
+        obj.SecondOrderLinear = True
+        obj.addProperty(
gmshtools.py:
diff U C:/Users/aio/FreeCADcode/src/Mod/Fem/femmesh/gmshtools.py C:/Users/aio/Miniconda3/envs/freecad/Library/Mod/Fem/femmesh/gmshtools.py
--- C:/Users/aio/FreeCADcode/src/Mod/Fem/femmesh/gmshtools.py	Mon Dec 16 18:48:20 2019
+++ C:/Users/aio/Miniconda3/envs/freecad/Library/Mod/Fem/femmesh/gmshtools.py	Mon Dec 16 18:42:53 2019
@@ -759,0 +760,5 @@
+        if hasattr(self.mesh_obj, "SecondOrderLinear") and self.mesh_obj.SecondOrderLinear is True:
+            geo.write("Mesh.SecondOrderLinear = 1; // Second order nodes are created by linear interpolation instead by curvilinear\n")
+        else:
+            geo.write("Mesh.SecondOrderLinear = 0; // Second order nodes are created by linear interpolation instead by curvilinear\n")
@@ -761 +766 @@
Patches.zip
(967 Bytes) Downloaded 5 times
What do you think?
bernd
Re: Neg. Jacobians at Surface 2nd Order Elements
Postby bernd » Tue Dec 17, 2019 4:47 am
I had problems to apply the patches thus I just copied the code ...
Is this what you would like to add? https://github.com/berndhahnebach/FreeC ... it/4141d4e
UR_
Postby UR_ » Tue Dec 17, 2019 7:39 am
Yes, that's right.
Jee-Bee
Postby Jee-Bee » Tue Dec 17, 2019 8:24 am
nice addition!
bernd
Postby bernd » Tue Dec 17, 2019 10:31 am
UR_
Postby UR_ » Tue Dec 17, 2019 3:28 pm
Concerning gmshtools.py, I've send you wrong diff file.
I'm so sorry, my fault :oops: :man_facepalming:
This is the right one:
gmshtools.py
(41.57 KiB) Downloaded 6 times
(Because you have problems to process my diff files, I've attached whole file, so you can diff yourself)
If it's done, you are allowed to start your sermon, something like: "Please familiarize yourself with Git" or something else. :roll: :lol:
bernd
Postby bernd » Tue Dec 17, 2019 6:12 pm
git commit e7be69e
Ahh, btw it would be much easier for all involved if you would use git and github for PRs :mrgreen:
vocx
Postby vocx » Tue Dec 17, 2019 7:41 pm
Maybe you noticed already but FEM has a failing test, which seems to be due to this.
freecad -t TestFem
FAIL: test_solver_elmer (femtest.app.test_solverframework.TestSolverFrameWork)
  File "/opt/freecad-build-main/Mod/Fem/femtest/app/test_solverframework.py", line 188, in test_solver_elmer
    self.assertFalse(ret, "GMSH geo write file test failed.\n{}".format(ret))
AssertionError: 'Comparing /opt/freecad-build-main/Mod/Fem/femtest/data/elmer/group_mesh.geo to /tmp/FEM_unittests/FEM_solverframework/SolverElmer/group_mesh.geo failed!\n--- \n+++ \n@@ -15,0 +16 @@\n+Mesh.SecondOrderLinear = 1; // Second order nodes are created by linear interpolation instead by curvilinear\n' is not false : GMSH geo write file test failed.
@@ -15,0 +16 @@
bernd
Postby bernd » Tue Dec 17, 2019 9:27 pm
confirmed ... elmer test fails ...
./bin/FreeCADCmd --run-test "femtest.app.test_solverframework.TestSolverFrameWork.test_solver_elmer"
bernd
Postby bernd » Tue Dec 17, 2019 9:45 pm
