I like
very simple examples
thus I made it even simpler ... It can not work because the vertex is missing in the mesh, but FreeCAD hangs, what shold not happen ... I will have a look on this.
CalxuliX ccx tools solver!
MechanicalSolidMaterial has empty References.
ConstraintFixed has Face reference shapes.
ConstraintForce has Vertex reference shapes.
Check prerequisites.
Start writing CalculiX input file
writerbaseCcx --> self.file_name --> /tmp/fcfem_4744m4tx/FEMMeshGmsh.inp
Constraint fixed: ConstraintFixed
Finite element mesh nodes will be retrieved by searching the appropriate nodes in the finite element mesh.
ReferenceShape ... Type: Face, Object name: Box, Object label: Cube, Element name: Face4
Constraint force: ConstraintForce
The appropriate finite element mesh node load values will be calculated according to the finite element definition.
ReferenceShape ... Type: Vertex, Object name: Vertex, Object label: Vertex, Element name: Vertex1
Unexpected error when writing CalculiX input file: <class 'IndexError'>
Running the Python command 'FEM_SolverRun' failed:
File "/usr/local/Mod/Fem/femcommands/commands.py", line 1059, in Activated
run_fem_solver(self.selobj)
File "/usr/local/Mod/Fem/femsolver/run.py", line 101, in run_fem_solver
fea.run()
File "/usr/local/Mod/Fem/femtools/ccxtools.py", line 1004, in run
self.write_inp_file()
File "/usr/local/Mod/Fem/femtools/ccxtools.py", line 755, in write_inp_file
self.inp_file_name = inp_writer.write_calculix_input_file()
File "/usr/local/Mod/Fem/femsolver/calculix/writer.py", line 114, in write_calculix_input_file
self.write_calculix_one_input_file()
File "/usr/local/Mod/Fem/femsolver/calculix/writer.py", line 196, in write_calculix_one_input_file
self.write_constraints_force(inpfile)
File "/usr/local/Mod/Fem/femsolver/calculix/writer.py", line 1096, in write_constraints_force
self.get_constraints_force_nodeloads()
File "/usr/local/Mod/Fem/femsolver/writerbase.py", line 276, in get_constraints_force_nodeloads
frc_obj
File "/usr/local/Mod/Fem/femmesh/meshtools.py", line 775, in get_force_obj_vertex_nodeload_table
(elem_info_string, {node[0]: node_load / node_count})
list index out of range
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.19.19160 (Git)
Build type: Unknown
Hash: 4f56a64ace6e5a72394aa71e44fdbc3c85337989
Python version: 3.7.3
Qt version: 5.11.3
Locale: German/Switzerland (de_CH)
