Actually, we don't have an equation here but an assignment of an expression to a variable.
Units of user defined equation in FEM result
Re: Units of user defined equation in FEM result
git commit 53bbf09bf implements the grammar for the ply parser.
Currently the code inside _ViewProviderFemResultMechanical.py is disabled because it requires the Python ply package.
To test the code activate it and comment out the call of eval().
But you can not use numpy now?
Note sure if I find some time today, but maybe I can try that on the weekend!
I don't think that numpy includes an expression parser and that's what we need here.But you can not use numpy now?
See also:
https://stackoverflow.com/questions/412 ... py-ndarray
this uses a hand-written parser https://github.com/Axiacore/py-expression-eval
https://numexpr.readthedocs.io/projects ... index.html
This implements a specialized parser tailored for numpy but it's all in C and thus more difficult to use. At least for Debian & co there are official packages available but for Windows we then have to upgrade the LibPack again.
Therefore using ply is the easiest because there is also a package for Debian and for Windows devs with an older LibPack they can easily upgrade it. All what they have to do is adding the ply directory from the link above to the site-packages directory of the LibPack.
I had to regenerate the FEM result, because I got this error:wmayer wrote: ↑Fri Feb 14, 2020 12:24 am git commit 53bbf09bf implements the grammar for the ply parser.
File "/usr/lib/freecad-daily/Mod/Fem/femguiobjects/_ViewProviderFemResultMechanical.py", line 465, in calculate
rx = np.array(self.result_obj.ReinforcementRatio_x)
AttributeError: 'FeaturePython' object has no attribute 'ReinforcementRatio_x'
WARNING: Couldn't open 'parser.out'. [Errno 13] Keine Berechtigung: '/usr/lib/freecad-daily/Mod/Fem/femtools/parser.out'
WARNING: Token 'COMMENT' defined, but not used
WARNING: There is 1 unused token
Generating LALR tables
WARNING: Couldn't create 'femtools.parsetab'. [Errno 13] Keine Berechtigung: '/usr/lib/freecad-daily/Mod/Fem/femtools/parsetab.py'
But it looks like the result is written into the fields min,avg and max and also the nodes are colored correctly I think.
If you enter some illegal input, like np.sqrt(x), then you just get the error message on the python console. But other than that it looks quite good!
There was recently a PR that changed a property name. Maybe this caused the problem.Traceback (most recent call last):
On my system I couldn't see that it wants to create such a file. I wonder what happens if you try to open an OpenSCAD file? Therefore ply is also used.WARNING: Couldn't open 'parser.out'. [Errno 13] Keine Berechtigung: '/usr/lib/freecad-daily/Mod/Fem/femtools/parser.out'
Whenever I modified the grammar file and imported it I got a message "Generating LALR tables" but I don't know where things are stored.Maybe the grammar file should be generated in the ~/.FreeCAD folder?
The question is how to handle this? The example I used catches exceptions when an unknown identifier is used, prints a message but then sets the identifier to 0. We can leave it like this or remove the exception handling from the grammar file and let the application code handle it.If you enter some illegal input, like np.sqrt(x), then you just get the error message on the python console. But other than that it looks quite good!
I converted some file to CSG and then I get this error message:wmayer wrote: ↑Sat Feb 15, 2020 7:05 pmOn my system I couldn't see that it wants to create such a file. I wonder what happens if you try to open an OpenSCAD file? Therefore ply is also used.WARNING: Couldn't open 'parser.out'. [Errno 13] Keine Berechtigung: '/usr/lib/freecad-daily/Mod/Fem/femtools/parser.out'
WARNING: Token 'DOT' defined, but not used
WARNING: Token 'WORD' defined, but not used
WARNING: There are 2 unused tokens
WARNING: Couldn't create 'parsetab'. [Errno 13] Keine Berechtigung: '/usr/lib/freecad-daily/Mod/OpenSCAD/parsetab.py'
End processing CSG file
I'm using this version:
OS: Debian GNU/Linux bullseye/sid (i3/i3)
Version: 0.19.19603 (Git)
Hash: 62251e3b398ce7d46aba6c84d68da990bfb8b0f9
Python version: 3.8.2rc1
Qt version: 5.12.5
Locale: German/Austria (de_AT)
Do you get it each time or only once?I converted some file to CSG and then I get this error message:
In case it happens all the time there is a way to fix it. The function yacc() provides a keyword argument outputdir where an arbitrary path can be passed to write out the parsetab.py file.
I tried to open the csg file from the list of recent files, but this gives me this error:
The csg file does not open from this list...
However, opening it via the File menu still works, but I get this output every time (opened the file three consecutive times):
<string>(26)<class 'SyntaxError'>: ('invalid syntax', ('<string>', 1, 8, 'import \n'))
