Thermal Analysis Of a Fluid
tthomas20
Postby tthomas20 » Fri Jan 17, 2020 6:48 pm
Hi All,
I am very new to FreeCAD and even newer to python. I have been trying to learn the FEM workbench, mostly for the thermal analysis. I can get it to work with relatively simple, solid objects no problem. However, I have been trying to simulate the expansion of air inside of a container such as a window (where I am having the most trouble). I keep getting a long list of errors after I run CalculiX and I have no idea what to do with them. I have searched google, the forums, uninstalled and reinstalled FC, and nothing seems to really address my problem.
After meshing I get this message but the mesh appears
Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid
And after I run CalculiX I get this message but no result mesh
Active Task Dialog found! Please close this one before opening  a new one!
FEM preferences working dir setting is empty, the solver working directory is used.
All working Dir settings are empty: ''.
Working directory: '' doesn't exist.
Dir 'C:\Users\tthomas\AppData\Local\Temp' will be used instead.
FemToolsCCx.setup_working_dir()  -->  self.working_dir = C:\Users\tthomas\AppData\Local\Temp
SolidMaterial has Solid reference shapes.
SolidMaterial001 has Solid reference shapes.
FluidMaterial has Solid reference shapes.
FemConstraintFixed has Face reference shapes.
FemConstraintHeatflux has Face reference shapes.
FemConstraintInitialTemperature has empty References.
card_path:
Previously used material card cannot be found in material directories. Add document material.
False
FemInputWriterCcx --> self.dir_name  -->  C:\Users\tthomas\AppData\Local\Temp\
FemInputWriterCcx --> self.main_file_name  -->  FEMMeshGmsh.inp
FemInputWriterCcx --> self.file_name  -->  C:\Users\tthomas\AppData\Local\Temp\FEMMeshGmsh.inp
Materials
Constraint: SolidMaterial --> We have mesh groups. We will search for appropriate group data.
  found mesh group for the IDs: SolidMaterial_Volumes, Type: Volume
Constraint: SolidMaterial001 --> We have mesh groups. We will search for appropriate group data.
  found mesh group for the IDs: SolidMaterial001_Volumes, Type: Volume
Constraint: FluidMaterial --> We have mesh groups. We will search for appropriate group data.
  found mesh group for the IDs: FluidMaterial_Volumes, Type: Volume
Count FEM elements as sum of constraints:  19341
Count FEM elements of the FreeCAD FEM mesh:   19341
True
Constraint fixed: FemConstraintFixed
  found mesh group for the IDs: FemConstraintFixed_Nodes, Type: Node
  nodes where retrieved from existent FEM mesh group data
Writing time input file: 2.13 seconds
runCalculix
run CalculiX at: C:/Users/tthomas/AppData/Local/FreeCAD 0.18/bin/ccx.exe with: C:\Users\tthomas\AppData\Local\Temp\FEMMeshGmsh
calculixStarted()
PySide2.QtCore.QProcess.ProcessState.Running
calculixFinished() -1
PySide2.QtCore.QProcess.ProcessState.NotRunning
PySide2.QtCore.QRegExp('\*ERROR.*\n\n', 1, 0)
CalculiX done without error!
We will load the ccx frd and dat result file.
Read ccx results from frd file: C:\Users\tthomas\AppData\Local\Temp\FEMMeshGmsh.frd
FEM: No nodes found in Frd file.
Problem on frd file import. No nodes found in frd file.
FEM: No result object in active Analysis.
Read ccx results from dat file: C:\Users\tthomas\AppData\Local\Temp\FEMMeshGmsh.dat
Has anyone tried thermal analysis on a fluid in FC before with FEM? Any help will be appreciated.
(Sorry I am having trouble attaching the actual file)
OS: WIndows 10
Word Size of OS: 64-bit
Word Size of FreeCAD: 64-bit
Version: 0.18.4.980bf90
Branch: Master
Python Version: 3.6.6
Qt Version: 5.6.2
Coin Version: 4.0.0.0
Re: Thermal Analysis Of a Fluid
Postby Kunda1 » Fri Jan 17, 2020 7:36 pm
bernd
Postby bernd » Sat Jan 18, 2020 1:45 pm
This meshing error can be ignored. There us a topic about it, but I can not find it ATM.
bernd
Postby bernd » Sat Jan 18, 2020 1:49 pm
Solver input file writing seams to have worked. Calculix, the solver ended with an error. We would need the file.
If the file is > 1 MB, clear (not delete) the mesh.
bernd
bernd
Ahh, welcone to FreeCAD FEM
bernd
Postby bernd » Sun Jan 19, 2020 1:31 pm
there is an example ... but you need 0.19 dev version
- start FreeCAD
- in Python console run
from femexamples import thermomech_spine as spine
spine.setup()
than activate the analysis and run the analysis ...
tthomas20
Postby tthomas20 » Mon Jan 20, 2020 11:33 am
Thanks for the advice and instructions. The file fits now and I will start installing 0.19
Standard Window.FCStd
(183.72 KiB) Downloaded 3 times
Postby Kunda1 » Mon Jan 20, 2020 12:43 pm
@bernd is there a page on the wiki describing this ?
bernd
Postby bernd » Mon Jan 20, 2020 3:46 pm
no wiki page yet how to start the FEM examples. see in FEM mod in femexamples at the end of each file is a Python command to copy.
On my to do is to add a menue entry for each example.
tthomas20
Postby tthomas20 » Mon Feb 03, 2020 4:00 pm
So here is where I'm at...I compiled FC 0.19 and ran the example @bernd gave me and it worked fine. I tried to simplify the problem by just copying the tutorial from https://www.freecadweb.org/wiki/FEM_She ... site_Block (which worked) and replacing the inner material with air and applying the thermal conditions I had before. Although this seems to work a little smoother, I still get the error
runCalculix
calculixStarted()
where the .frd and .dat files are empty. I have had trouble searching the forums for the exact cause of this error, thus I am back here to you. I attached the "simplified" version of the model
thermal analysis fo air in a box.FCStd
(15.6 KiB) Downloaded 1 time
