discussed e.g. here: https://forum.freecadweb.org/viewtopic. ... ie#p337254
bernd wrote:
source could be found here: https://github.com/UR-0/FreeCAD/commits ... straintTie
code works so far but isn't tested exhaustive.
Please can you have look.
So far two questions arose:
- Fem\femtools\ccxtools.py line 292
self.tie_constraints = self._get_several_member("Fem::ConstraintPython")
- plausibility checks aren't implemented ATM:
AFAIK,
only two faces per constrain are allowed by ccx,
only volume elements are allowed.
I guess it should be done in def accept from Fem\femguiobjects\_ViewProviderFemConstraintTie.py
or is there another preferred place?
