git commit 7dcc02dUR_ wrote: ↑Fri Jan 31, 2020 4:42 pmNo, I dreamed something like this (similar to my commit):Code: Select all
message += "{} has empty references.\n".format(c["Object"].Name)
*TIE constraint for ccx (aka "bonding faces")
Re: *TIE constraint for ccx (aka "bonding faces")
We need to find a solution for this problem: https://forum.freecadweb.org/viewtopic.php?f=18&t=43092
how about this? https://github.com/berndhahnebach/FreeC ... it/6c385b0bernd wrote: ↑Mon Feb 03, 2020 10:19 pm IMHO in the writer should be only code to write the file not to get the data out of the mesh. Furthermore did the contact only support tets and no quad and it used the very slow old depretiated method. Fixing it was on my TODO for years. Since tie would even more of this code introduce I decided to fix the contact code. Would be good to do this for the tie as well before merge. Would you give it a try. BTW: What is you opinion about the binary search. Is should be x-times faster! git commit da71719
Sorry, couldn't ATM, but looks nice.
Please note that in case of contact constraint, both faces (master and slave) could be the same face, so called self contact.
I think this isn't applicable for *TIE
http://mecway.com/forum/discussion/813/ ... y-calculix
Another difficulty will arise in case of *SECTION PRINT
Because there is no gap and concerning face is part of two touching solids, we need only volume elements touching positive side (front side) of face.
Backside and touching fem elements are not of interest.
Means, face and fem element's face has nearly same normal.
ahh ... will add some comments in this regard
BTW: tie is ready to merge IMHO
cools stuff ... https://www.youtube.com/watch?v=oZUEp4sPWpU would be good to know if this works in FreeCAD too ...
TODOs ... in the wiki
- new entry on FEM main page
- new command entry
- upload icon to wiki artwork
- new command entry
