*SECTION PRINT implemented for volume elements
bernd
Re: *SECTION PRINT implemented for volume elements
Post by bernd »
bernd wrote: Wed Apr 22, 2020 7:00 am due to some changes in ccx writer lately, I hat do change some lines to get the section print rebased ...
new code looks like this:
https://github.com/berndhahnebach/FreeC ... d55d091251
once again ... https://github.com/berndhahnebach/FreeC ... d55d091251
bernd
Post by bernd »
bernd wrote: Fri Apr 24, 2020 7:54 am
All good things come in threes https://github.com/berndhahnebach/FreeC ... d55d091251
bernd
Post by bernd »
bernd wrote: Fri Apr 24, 2020 3:09 pm
hopefully finished writer improvements with this https://github.com/berndhahnebach/FreeC ... d55d091251
HoWil
Post by HoWil »
bernd wrote: Wed Mar 11, 2020 11:36 am great
check view provider of result mechanical how to collect childs. Than do not add the dat obj to the analysis. It would be twice in tree.
A bit off-topic but related:
Is this the same reason why the SolverElmerOutput is not shown and incorporated into the analysis :?:
BTW: The SolverElmerResult is only added after the second run of the solver.
Screenshot from 2020-04-26 21-46-48.png (193.42 KiB) Viewed 951 times
bernd
Post by bernd »
yes, but on a different abstraction layer. I try to have a look on both. bernd
eventually no! Somehow elmer tasks uses a non existant attribut of the output object.
bernd
Post by bernd »
HoWil
Post by HoWil »
bernd
Post by bernd »
rebased onece again to the new FEM module structure and added the example. https://github.com/berndhahnebach/FreeC ... ctionprint
Setup the example with:
from femexamples.constraint_section_print import setup
setup()
bernd
Post by bernd »
UR_ wrote: :bell:
bernd
Post by bernd »
merged, but any testing is highly appreciated.
https://github.com/FreeCAD/FreeCAD/comp ... fc9471ab49
TODO: The unit test is missing. I will add this later on today.
