Minor Improvement for Task Panel ResultShow
UR_
Re: Minor Improvement for Task Panel ResultShow
Postby UR_ » Mon Feb 17, 2020 6:11 pm
bernd wrote:
Wed Feb 12, 2020 10:49 pm
How about removing the Avg value?
Stats member "avg" removed from result object.
Histograms added
Source: https://github.com/UR-0/FreeCAD/commits ... result_obj
Please have a look.
Migration of old result objects not yet implemented, so import a fresh calculated, ATM
HoWil
Postby HoWil » Mon Feb 17, 2020 6:40 pm
Nice!
Postby bernd » Tue Feb 18, 2020 4:37 am
cool addition :)
- is there a special reason for deleting the try here: https://github.com/UR-0/FreeCAD/commit/ ... 1R324-R327
- you forgot about the unit tests ... start FreeCAD and run
import Test, TestFem
Test.runTestsFromModule(TestFem)
import Test, femtest.testcommon
Test.runTestsFromClass(femtest.app.test_ccxtools.TestCcxTools)
Postby bernd » Tue Feb 18, 2020 4:49 am
I will fix the unit tests.
UR_
Postby UR_ » Tue Feb 18, 2020 6:31 am
Code was commented out just for debugging reasons. Should be restored at releasing.
But perhaps you wanna do some testing before.
Postby bernd » Tue Feb 18, 2020 7:21 am
no histogramm for me ATM ... I might miss some packages on my linux machine ...
https://github.com/berndhahnebach/FreeC ... its/femtmp
Postby bernd » Tue Feb 18, 2020 4:50 pm
no selected result type means no histogramm :oops:
merged and unit test fixed and code formating and debugging comments removed ...
UR_
Postby UR_ » Wed Feb 19, 2020 7:15 am
- Added a messagebox to give a hint in that case
- Added migration code to convert stat from old result object: (min, avg, max)->(min, max)
PR: https://github.com/FreeCAD/FreeCAD/pull/3079
Postby bernd » Wed Feb 19, 2020 8:37 am
merged and added the commit sha of origin change, this is the stuff which makes FreeCAD robust. We really need this, even if it is boring to develop.
cheers bernd
