Begging for help regarding temperature FEM analysis
Re: Begging for help regarding temperature FEM analysis
the topic is not solved if the errors are fixed! The topic is about pcb FEA modelling!
Cancel clear.
Hello all,
thanks for all your response and work that has been spend.
I'm trying to get an updated version but on that page its still 0.19.19858:
https://github.com/FreeCAD/FreeCAD/releases
Where do I get the mentioned 0.19.19946 from?
Thank you.
BR
Thank you.
BR
You must wait till the next update. Each OS package is generated separately from the rest and at different timeslighting_freak wrote: ↑Sat Mar 07, 2020 8:59 pm Where do I get the mentioned 0.19.19946 from?
Thank you.
wait just some days, may be after the weekend ...
You can also try to Compile on Docker I understood from a recent post that it now supports FEMlighting_freak wrote: ↑Sat Mar 07, 2020 8:59 pm Hello all,
Thank you.
BR
https://forum.freecadweb.org/viewtopic.php?f=4&t=42954
New win builds have been uploaded ...
just downloaded the new windows dev-release and I can confirm the errors are gone!
Thanks for that quick effort once more.
Let's come back to the main topic.
From LED datasheet one can see that this type consumes 0,15 Ampere x 9,80 Volts = 1,47W
In worst case I'd like to assume that this 1,47W are fully converted into heat...
From my current understanding the LED solder pads should be the faces carrying this heat flux, but I can't reach this faces after building the "compound" - object any longer. How is the process for correctly defined faces that are in touching condition?
EDIT: I tried also the "fragmented boolean" option - but in that case the mesh fails due to identical faces...
EDIT: I'm also willing to change the CAD model itself, if necessary. For example I could prepare a surface model that has only a single face in touching areas (often like this in lighting). So if it helps, just let me know.
There is the geometry and the current FEM setup... The "constraint temperature" is wrong. Due to the issue above I simply selected the face of the resin for heat flux definition.
By the way, while saving a FreeCAD project file from time to time this message appears:
Thank you.
File "json\__init__.py", line 231, in dumps
File "json\encoder.py", line 199, in encode
File "json\encoder.py", line 257, in iterencode
File "json\encoder.py", line 180, in default
<class 'TypeError'>: Object of type 'FeaturePython' is not JSON serializable
git commit 8b84a1cc94lighting_freak wrote: ↑Mon Mar 09, 2020 9:33 am By the way, while saving a FreeCAD project file from time to time this message appears:Code: Select all
Traceback (most recent call last): File "json\__init__.py", line 231, in dumps File "json\encoder.py", line 199, in encode File "json\encoder.py", line 257, in iterencode File "json\encoder.py", line 180, in default <class 'TypeError'>: Object of type 'FeaturePython' is not JSON serializable
Hello all,
Thanks for taking care of the error messages.
What's about the initial question about the "how to"?
Thank you.
BR
Thank you.
BR
