obj.Proxy.Type is a dict, not a string
UR_
Postby UR_ » Mon Mar 09, 2020 8:20 am
ViewProviderFemConstraint.py line 51 should be:
        file_name = self.Object.Proxy.Type.get("Type").replace("Fem::", "FEM_")
Shouldn't it? ;)
bernd wrote: :bell:
please compare git commit 5829fc4
bernd
Re: obj.Proxy.Type is a dict, not a string
Postby bernd » Mon Mar 09, 2020 2:11 pm
no not IMHO. I need to have a closer look ...
The time beeing the icons in tree view are deactivated for the python objects ... git commit 8b84a1cc94
bernd
Postby bernd » Tue Mar 10, 2020 7:56 pm
bernd
Postby bernd » Tue Mar 10, 2020 9:03 pm
git commit f41a942b0e works for me for most of the icons ...
all_objects.FCStd
(25.52 KiB) Downloaded 16 times
bernd
Postby bernd » Wed Mar 18, 2020 7:39 am
I have a file which shows the problem. Seams we need werner here ...
Two mesh regions, one does have an icon one not :shock:
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.19.20121 (Git)
Build type: Unknown
Hash: 2a50a19564a773b1977ee4158e6538dd0ca9315f
Python version: 3.7.3
Qt version: 5.11.3
Locale: German/Switzerland (de_CH)
Here is the relevant code https://github.com/FreeCAD/FreeCAD/blob ... py#L51-L66
error on file loading.
No icon returned for MeshRegion
{'Type': {'Type': 'Fem::FemMeshRegion'}}
icon_problem.FCStd
(69 KiB) Downloaded 16 times
Site Admin
Postby wmayer » Wed Mar 18, 2020 10:43 am
self=App.ActiveDocument.MeshRegion.ViewObject.Proxy
self.Object.Proxy.Type # {'Type': {'Type': 'Fem::FemMeshRegion'}}
self001=App.ActiveDocument.MeshRegion001.ViewObject.Proxy
self001.Object.Proxy.Type # 'Fem::MeshRegion'
I don't know why "{'Type': {'Type': 'Fem::FemMeshRegion'}}" is assigned to the Type attribute of the proxy class.
You can assign a new value to Type
self001.Object.Proxy.Type = 'Fem::MeshRegion'
and hide and show the object to fix its icon.
After changing the value of Type, saving the project and reloading it the old bad value is back. So, somewhere in the code something is wrong.
bernd
Postby bernd » Wed Mar 18, 2020 11:00 am
me neither, this is the problem I am facing with. OK, Fixing the object is not that difficault by Python. :)
bernd
Postby bernd » Wed Mar 18, 2020 11:11 am
I thought this happens at file load and thus it should be a problem in my FEM code somehow.
AFAIK the type property of the proxy is not saved in the FreeCAD file?! At least I could not found anything in Document.xml or GuiDocument.xml.
bernd
bernd
Postby bernd » Wed Mar 18, 2020 11:21 am
ahh I missed this, just tested and I get even more interfaced type dictionaries on saving and reloading ...
Site Admin
Postby wmayer » Wed Mar 18, 2020 11:22 am
The culprit is https://github.com/FreeCAD/FreeCAD/blob ... int.py#L42
If you change it to:
    def __setstate__(self, state):
        #if state:
        #    self.Type = state
        print (self, " ", state)
the broken icons are fixed. The printed content is:
<femobjects._FemMeshRegion._FemMeshRegion object at 0x7fe9f97441d0> {'Type': {'Type': 'Fem::FemMeshRegion'}}
<femobjects._FemMeshGmsh._FemMeshGmsh object at 0x7fe9f9610f60> {'Type': 'Fem::FemMeshGmsh'}
<femobjects._FemMeshGmsh._FemMeshGmsh object at 0x7fe9e40420b8> {}
<femobjects._FemMeshRegion._FemMeshRegion object at 0x7fe9e4042240> {}
So, in some of your __getstate__ methods you return an inappropriate dict.
