self.Object does return an error on file writing
bernd
Postby bernd » Mon Mar 09, 2020 6:09 pm
git commit f9c081f06d add self.Object to a View Provider class which is inherited from a base class. As soon as self.Object is added to a inherited class on document saving the obj raises an error ...
this commit is interessting too ... git commit 8b84a1cc94
- start latest FreeCAD
- open FEM 3D cantilever example
- save as file on disk (desktop or else where)
- error ...
$ ./bin/FreeCAD
FreeCAD 0.19, Libs: 0.19R19965 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
connect failed: Datei oder Verzeichnis nicht gefunden
  File "/usr/lib/python3.7/json/__init__.py", line 231, in dumps
    return _default_encoder.encode(obj)
  File "/usr/lib/python3.7/json/encoder.py", line 199, in encode
    chunks = self.iterencode(o, _one_shot=True)
  File "/usr/lib/python3.7/json/encoder.py", line 257, in iterencode
    return _iterencode(o, 0)
  File "/usr/lib/python3.7/json/encoder.py", line 179, in default
    raise TypeError(f'Object of type {o.__class__.__name__} '
<class 'TypeError'>: Object of type FeaturePython is not JSON serializable
vocx
Re: self.Object does return an erro on file writing
Postby vocx » Tue Mar 10, 2020 6:55 am
Yes, I don't know what you did, but the unit tests show those messages.
The tests don't seem to fail, so I have ignored the errors.
Site Admin
Postby wmayer » Tue Mar 10, 2020 3:11 pm
The problem is caused by the proxy object of FemGui::ViewProviderResultPython.
Gui.ActiveDocument.CalculiX_static_results.Proxy.__dict__
will give something like this
{'Object': <Fem::FemResultObjectPython object>, 'ViewObject': <View provider object at 0x3148560>}
which I think must be caused by the attach() method of git commit f9c081f06d49ee
When serializing a proxy object then first it's checked whether it implements the __getstate__ method and if yes its output will be used. If it doesn't have then the __dict__ attribute is used and if this doesn't exist then the object as is will be saved. See PropertyPythonObject::toString()
Now due to the implementation of attach() the __dict__ attribute contains an object and its view provider that are objects that cannot be serialized. To solve the issue you should implement the methods __getstate__ and __setstate__. As a default implementation it's sufficient to do:
def __getstate__(self):
   return None
def __setstate__(self, data):
   return None
Site Admin
Postby wmayer » Tue Mar 10, 2020 3:33 pm
bernd
Postby bernd » Tue Mar 10, 2020 5:11 pm
Got it! Many thanks for the explanation. git commit 062d782236 was the reason for all the excitement on my side. I did not know what these methods are used for ...
bernd
Postby bernd » Tue Mar 10, 2020 5:19 pm
