uwestoehr wrote: ↑Tue Jul 26, 2022 2:05 am
HoWil wrote: ↑Fri Aug 07, 2020 8:33 pm
Here the model for Tutorial1 for the body heat source
Hello HoWil, I am currently checking if the Elmer support is still OK and took as start this file.
Sadly, it does not work anymore:
- the value for the BodyHeatSource is zero in your file
does not have this problem.
- when I set it to 0.01 as they do in the Elmer tutorial, I get as result 293 K for the whole body
Do you have an idea why could be the reason?
Works as expected. See below...
According to the documentation
http://www.nic.funet.fi/pub/sci/physics ... orials.pdf page 8: "The maximum temperature should be about 586.5 K. "
- Screenshot from 2022-07-31 14-54-34.png (207.82 KiB) Viewed 1154 times
- Screenshot from 2022-07-31 14-55-00.png (425.01 KiB) Viewed 1154 times
I used:
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 2022.725.14555 (Git shallow)
Branch: (HEAD detached at 2022.07.25-edge)
Hash: d3895564b96aa0c2ed57bcd10034535f1043a396
Python version: 3.8.10
Qt version: 5.15.3
Coin version: 4.0.1
OCC version: 7.6.2
BTW: I had some difficulties with the below listed FC-Stable via Flatpak it does not find ElmerGrid even when i manually add the path /usr/bin/
OS: KDE Flatpak runtime (ubuntu:GNOME/ubuntu)
Version: 0.20.29177 (Git)
Python 3.9.9, Qt 5.15.5, Coin 4.0.0, Vtk 8.2.0, OCC 7.6.2
Installed mods:
* Assembly3 0.11.3
