GSoC2020, FEM: extend examples
Re: GSoC2020, FEM: extend examples
Ahh, yes will go for it tomorrow morning (Zürich Time)
@bernd, do you think we can have a general method for testing examples, in test_ccxtools.py? Something similar to the general method in manager.py?
Hmm, done?
Yes, done
Next stop 3rd of July for the second evaluation.
BTW: Very good work so far, thanks
- You means nothing here, Bernd did the evaluation.
- Screenshot_20200703-063856.png (107.16 KiB) Viewed 955 times
unit tests should be explizit triggered. A method which simplifys the process exists already.
but with the latest changes it is very simple to trigger the unit test. Just a few lines of code are needed. https://github.com/FreeCAD/FreeCAD/blob ... #L176-L183
Would you rebase your branch on latest master and add a ccxtools unit test for every example? Furthermore some history rewriting would be needed too.
I would suggest two commits for each example, one commit which add the example, and one commit just behind the first, which adds the unit test for this example. Drop a note if you have problems with the history rewriting.
We could start to merge some of the examples into master than.
I'm still changing code in elmer unit tests. I will post a note if this is finished.
Furthermore a Z88 writing test. We should start with the static box example. A very good start to implement is the solver calcuix framework unit test module. See https://github.com/FreeCAD/FreeCAD/blob ... alculix.py Do not forget to register the new module here: https://github.com/FreeCAD/FreeCAD/blob ... App.py#L38
Lot's of stuff for the days to come ...
would it be possible to write setup instead of OK on the ok-button? Would look better beside the run on the button.
This should do, there are unit test for all ccx examples: https://github.com/Sudhanshu-Dubey14/Fr ... emexamplesbernd wrote: ↑Fri Jul 03, 2020 8:08 ambut with the latest changes it is very simple to trigger the unit test. Just a few lines of code are needed. https://github.com/FreeCAD/FreeCAD/blob ... #L176-L183
There are some improvements in multibody face analysis and multibody analysis examples to pass the tests.
Also, I have changed this commit: https://github.com/Sudhanshu-Dubey14/Fr ... e11e54882c to be according to the new test methods.
When I run tests for all of FEM, I get:
ERROR: test_pyimport_all_FEM_modules (femtest.app.test_common.TestFemCommon)
File "/run/media/sudhanshu/Thunder/Repos/FreeCAD_sd/build_nonetgen/Mod/Fem/femtest/app/test_common.py", line 142, in test_pyimport_all_FEM_modules
im = __import__("{0}".format(mod))
File "/run/media/sudhanshu/Thunder/Repos/FreeCAD_sd/build_nonetgen/Mod/Fem/femsolver/elmer/equations/fluxsolver.py", line 41, in <module>
class Proxy(linear.Proxy, equationbase.FluxsolverProxy):
AttributeError: module 'femsolver.equationbase' has no attribute 'FluxsolverProxy'
FAIL: test_femobjects_open_de9b3fb438 (femtest.app.test_open.TestObjectOpen)
File "/run/media/sudhanshu/Thunder/Repos/FreeCAD_sd/build_nonetgen/Mod/Fem/femtest/app/test_open.py", line 151, in test_femobjects_open_de9b3fb438
self.assertEqual(
AssertionError: <class 'femsolver.elmer.equations.flux.Proxy'> != <class 'NoneType'>
Ran 65 tests in 23.321s
FAILED (failures=1, errors=1)
So if I am able to get you right, I need to:bernd wrote: ↑Fri Jul 03, 2020 1:35 pm Furthermore a Z88 writing test. We should start with the static box example. A very good start to implement is the solver calcuix framework unit test module. See https://github.com/FreeCAD/FreeCAD/blob ... alculix.py Do not forget to register the new module here: https://github.com/FreeCAD/FreeCAD/blob ... App.py#L38
1. Make a static box example for z88 or adopt the boxanalysis_static example for z88.
2. Take inspiration from calculix solver framework unit test module and make one for z88 too.
Right?
Which means I first need to install Z88 on my system.
