Sudhanshu wrote: ↑Tue Aug 11, 2020 8:55 am
So we should wait till this is merged in master, right.
I hope I can show the results of this model done with the free-textinput- branch until sunday.
But you can try it yourself if you find the time to play with it!
Alternatively, you could edit the .sif file created by FC (with pressing 'write' in the 'Solver control' of Elmer) and replace the boundary section of the inlet with the expression given above. You can than run the simulation with/in FC (without over-writing the .sif and model again, simply run the simulation with 'Run').
After that you could run the original model given with the tutorial by executing the following commands after replacing the following line in the .sif file called 'compress_step.sif' given in the 'FlowStepCompressible'- tutorial-folder
' Post File = "compress_step.ep"'
to
' Post File = "compress_step.vtu"'
and run the simulation after creating the mesh with
ElmerGrid 1 2 mesh.grd
ElmerSolver compress_step.sif
After that you will find several .vtu files in the 'mesh' subfolder which you can import as fem-result objects into FC and compare it with your modified model done in FC!
